Priming fuel bulb inside engine compartment
Feb 16, 2021
467
Hunter Legend 35.5 Bellingham
I recently purchased this Atwood priming bulb, only to learn it is only suitable for temps up to 120° Fahrenheit.
I would like to place a priming bulb within the engine compartment to easily prime my fuel system (and skip the inefficient lift pump method). Has anyone done so with a temperature resistant priming bulb? I definitely don’t want the bulb to fail and start siphoning fuel into the engine compartment.
If none exist, I may just have to install this at the tank and have someone else pump while I work the bleeder screws. I would rather be able to do this solo though.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
What's inefficient about the lift pump method? Wondering; I assume by lift pump you mean the electric fuel pump, not the on-engine low pressure pump. I just attach a remote started switch to my electric pump so I can activate it while sitting at the engine when bleeding; though, bleeding has only rarely been necessary, with the built in hand pump on my Racor.
capta
Jun 4, 2009
5,006
I put mine above the tank in the salon hatch to ensure it didn't get too how. Lasted 6+ years. It did mean it was a two person operation, but that worked for my wife and I. It also facilitated getting fuel easily, as I added a spigot in the engine room.
I heartily recommend the priming bulb (though Mainesail does not), if not directly at the tank somewhere convenient, outside the engine compartment.
Feb 16, 2021
467
I mean the built in low pressure pump. Wiring a switch to the fuel pump sounds good, but if the integrated Racor pump is sufficient, that would be the easiest. I did reach out to Racor about priming the entire system, and they told me to only prime the Racor with it. Is it common practice to just use the integrated pump to prime the entire system, not just the Racor?
How hard is it to pump diesel a few feet through a 5/16" hose? How often is it necessary to bleed the fuel system?
If the filter is below the fuel level in the tank, it only necessary to start a siphon to fill the filter and then it is only a few feet through small diameter hose to the high pressure pump.
There are options in all projects.
What would cause you to prime the engine?
  • If I change the engine fuel filter I have to prime my engine.
  • If I run dry I have to prime the engine
  • If the filter gets clogged I have to prime the engine
There are 3 events that I have experienced. The time to use the manual lift pump took in these events took from 10 to 30 minutes. Depending on where your fuel tanks are located it is a simple or a bugger of a task. An electric fuel pump is a valuable option.
Sure you can get a manual bulb. It can be located in a safe space but eventually it will fail. Diesel will either leak all over you hands or worse. Then your left with no pump and a severed fuel line.
If this is important then get a good electric pump. Walbro makes excellent pumps.
While you’re at it why not create a fuel polishing capability. Some plumbing parts can create a manifold allowing you to move fuel through your Racor and back to the tank.
If this interests you and you want an elegant solution, send me a PM.
Likes: JBP-PA
Feb 16, 2021
467
Manual lift pump seems pretty fickle on my 3GM. It’s difficult to tell if I’m actually getting flow from it after 10 minutes of pumping, and I end up cranking the shaft over to see if I can get more flow out of each stroke. A bit of a time consuming guessing game I’d rather skip by just having a more effective pump that is clearly moving the fuel, and quicker.
Is the integrated pump in the Racor not a viable for priming the entire system? I’m not sure why Racor recommends against doing it.
Nov 22, 2011
1,277
Ericson 26-2 San Pedro, CA
This is how I have my Yanmar 1GM set up (see attached). I don't really use it for fuel polishing--though I suppose I could. It's primary purpose is to deal with what is being discussed in this thread: priming the Racor fuel filter and bleeding the system of air.
This system is really fantastic. I have a toggle switch in the engine compartment that runs the electric fuel pump without having to energize the engine panel. With the valve set in the priming (polishing) position, it fills my large Racor 500 lickety split. Then, when I set the valve to send the fuel to the injector pump, I can crack the bleed points and get any lingering air out of the system.
Another advantage of this system is that you no longer are using Yanmar's mechanical lift pump. If/when the diaphragm fails on that pump, its failure mode is to dump fuel into the crankcase! No bueno. You can still leave the mechanical pump on the engine; you simply disconnect it. It doesn't hurt a thing to leave it installed. Or, if you prefer, you could remove the pump and fabricate a cover plate to cap the hole.
7,202
CC 30 South Florida
Nothing wrong with the mechanical lift pump method to bleed air from the fuel lines. If done properly a little work will insure good results. A manual bulb pump made of rubber should not even be considered unless used in a portable auxiliary can for emergency. An electrical fuel pump takes away the diesel engine capability to run without the need for electricity. Simplicity is the heart of the engine's reliability, start adding things and the chances for things to fail increase besides the addition to the factors of diagnosis.
Nov 22, 2011
1,277
Many diesel engines already use electric fuel pumps. My previous M25XP did. And they are highly reliable. Plus, if they do fail at least they don’t run the risk of dumping fuel into your crankcase.
In the mod I suggested there’s no reason you can’t leave the mechanical pump on the engine but disconnected. It could be there if one wanted to hook it back up for some reason.
Trying to prime an empty filter with that little thumb priming lever is purgatory. Good luck doing that in a seaway, as sometimes happens with filter clogs. With a Racor 500 and the system shown in the PDF, I could swap filters and prime the engine in minutes without spilling a drop, even on a pitching boat.
Likes: FastOlson
Feb 16, 2021
467
I am skipping putting a priming bulb in the engine compartment. Seems a bad idea. Putting a bulb closer to the tank is pointless for me as I want to be able to prime unassisted. I used the integrated Racor priming pump after switching out the element, and as the output descends from it, I didn’t need to prime the secondary. Engine started right up.
I will try using the integrated pump to prime the secondary next time I replace it.
I did install a vacuum gauge into the second output of my Racor, so hopefully that gives me indication of when to replace the primary.
11,722
On Yanmar engines, the manual pump just needs the crank rotated a bit until it feels like it’s working.
I don’t know a single priming bulb rated for below deck use. years ago I had a trawler customers below deck bulb fail. it totaled the boat.. I posted an image of it here ..
May 24, 2004
7,202
CC 30 South Florida
Fill the filter bowl with fuel before installing. Gravity should lead fuel to the lift pump so give the engine starter a few cranks . Open the bleed screw and take over with the lift pump lever to expel enough air to get the engine started. With the engine running open the bleed screws gradually to bleed off any remaining trapped air. Clean up any excess fuel that may have spilled.
Feb 16, 2021
467
@Benny17441 my engine seems relatively smooth but is shaking too much to bleed the screws when running. The change ended up being easy though. The diesel in the old element was contaminated so I disposed of it. I used the integrated pump to bleed the primary, then once that was clear of air, I simply started the engine. I don’t believe any air was in the system after bleeding the primary, as the lines descend from it and gravity keeps fuel in them and prevents air from entering.
1,970
Endeavour 42 Cruisin
I have a walbro electric pump in line. it has plenty of head lift capability to pull fuel up from the bottom of the tank.
If the engine is running, it isn't necessary to bleed the lines because fuel is getting to the cylinders. Any residual air in the line will work its way out.
Likes: skunther
Sep 24, 2018
3,989
Catalina 30 MKIII Chicago
I have an electric fuel pump installed by a previous owner. I have it connected to the choke terminal on the key/ignition switch. Push the key in to prime, start engine, fuel continues to flow through the pump when the pump no longer has power applied to it. The engine's own pump takes over once it's started
1,164
Hunter H30 1982 Chicago IL
This seems to be a recurring topic. My response to related question last spring seems relevant. In short: No to bulbs, add an isolation valve, try suction. Rather than rewriting the whole post, I’ve attached a link. See Post #9.
467
I hadn’t thought of that. I don’t see how I’d attach the oil extractor to the bleed valve screw though. Does your bleed screw have a bead attachment on top? Do you happen to have a picture of your setup?
Oct 6, 2007
1,164
Not the ideal photo angle, but all I had on hand. It’s the air accumulator screw at the red arrow. I take it out completely and just the jam the small suction tube into the opening. Then finish with the screw back in and the manual pump. Just minimizes the hand pumping needed. Note also that I have an in-line shut-off valve right at the inlet side of the primary Racor filter to minimize how much line I have to bleed.
This is the vacuum oil extractor I have.
