Bomar hatch dog
May 7, 2023
86
catalina 27 lake st clair
The hatch dog latch broke so I need to replace it. It’s held in place by a pin. Anyone know how to get that pin out ? (Ignore the extra wire..it was used to hold down the hatch while I fix the latch)
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I used to have a boat with Bomar hatches like this. I recall that you need a roll-pin punch to knock those pins out. I don't recall what size.
Here's a set:
9 Pieces Roll Pin Punch Set, HORUSDY Removing Repair Tool with Holder for Automotive, Watch Repair,Jewelry and Craft
Likes: BTC1984
May 7, 2023
86
The latch dog snapped at the red line. There is a roll pin that goes through the hole (green arrow) need to know how to get the roll pin out.
86
FYI- the lazy jib sheet lodged under the hatch and the jib filled with air before I could tighten the opposite jib sheet. The pressure from the jib on the sheet ripped the hatch open. Lesson learned.
jviss
Feb 5, 2004
7,090
Ugh, that sucks!
jviss
Feb 5, 2004
7,090
Yes, you should be able to see the end of the roll pin; use the right size punch and punch it out with a nice, light hammer. :)
Likes: BTC1984
May 7, 2023
86
Completed successfully. The pin is called a tension pin. I tried a nail, a screw, a bolt none of them worked to get the tension pin out. When I bought the correct punch it was easy. Buy the punch ! Also you will see in the photo for the last part I used a vice grip. Clamp the vice grip on the pin and hit the vice grip with the hammer. The new latch dog and pin went in easily. Mission accomplished.
jviss
Feb 5, 2004
7,090
It's the same as a roll pin, as I had mentioned. Did you use a roll pin punch?
I have a set of roll pin punches. It's a common fastener on AR style rifles. The roll pin punch works well, a normal pin punch not nearly as well.
Likes: BTC1984
May 7, 2023
86
I saw your post about the punch. So I went to harbor freight and bought a basic pin punch set. It worked great.
Likes: jviss
