I had a functional water system. Accidentally ran one of my tanks dry, and then water pump wouldn’t shut off. Pulled air through it by mistake and noticed what I did and so I shut off the pump. Now I needed to figure out how to prime the system..
Got the system primed and can pull water to hand pumps. I also loosened clamp leading up to the water pump to make sure water is leading right up to it. Water pump still won’t pump water to main faucet.
I have a Shurflo model 2088-423-344 water pump and then a Jabsco accumulator tank. (I’ve also got a hot water tank in aft storage bay behind the galley sink, unrelated but important part of water system.) Anyone have any ideas of potential fixes? And if not, any ideas of potential upgrades to make it all work again?
One idea is replace water pump with a self-priming pump. If this is a good idea, what product is compatible? And should I keep the accumulator tank with the new pump?
Advice is much appreciated. If anyone helps me fix it I’ll crew or skipper for you on my boat or yours, feed you brunch, etc. Puget Sound. Boat is Cascade 36, 1982.
