The question is whether the Cal 39 has the dreaded mild steel mast support beam (or "bird," as they called it at the factory) that a number of other Cal models do. I don't know first hand, but
it sounds like it does.. It's something you'll want to be certain about.
Exactly!!! Read something similar but not comprehensible to me. It wrongly lead me to believe it was a DECK MAST STEP with a compression post. Will certainly look around for more info on this to see if this CAL 39 has this mild steel support beam.
And the post you linked is from MIAMI!!! lol I am leading to believe we are talking about the same darn boat. If such is the case, I have been asking a million questions and the owner and the broker ... well.. i'll wait to learn more on my own.
EDIT ADD
I read the survey and it says " replace port chain plate and shroud.." and recommend "rigging inspection".
I was provided with a list of things done and not done,
2 are
-rigging inspection complete
-chain plate and shroud NOT replaced.
I asked for info on the inspection of rigging results but don't get anywhere with that question.
Interestingly in that week, I heard the story of a local sailor, much more novice than me, who went out on 15 knots and on a beam reach his chain plate broke and.. well standing rigging come down. I asked that group of friends how often now after that story do they reckon they would change /check their rigging and non answered check it often nor change it every 10 years lol...
He showed me a picture of the chainplate, and had signs of corrosion but could not tell if the cracking /crevices was before the chain plate gave way.
