When I first start diesel I prime for 15 seconds then hit start. Nothing but fuel pump running and starter clicking. Try a few times. Walk away. When I try again 10 min later it starts. New solenoid?
A weakly engaging starter relay is almost always a result of insufficient voltage, bad connection, weak battery, undercurrent.…and starter clicking.
This is a recommended procedure when starting an engine which has not been run for a few weeks. You only want to do it for about 5-10 sec. However, you're not priming the lines with fuel, you're wetting the rings and cylinder walls with oil. Seals much better (higher compression and less wear) than trying to start dry. You'll want to wait about one minute after running the starter motor without starting to allow the oil to spread and then start the engine (without the stop).When I first start diesel I prime for 15 seconds then hit start.
But if he’s just getting a click he’s not turning the engine, so not “priming” in the sense you mean. “Priming” by just letting the the fuel pump run should be unnecessary as Don said. Holding the glow plugs on for that long might be necessary for some engines in some temperatures.This is a recommended procedure when starting an engine which has not been run for a few weeks. You only want to do it for about 5-10 sec. However, you're not priming the lines with fuel, you're wetting the rings and cylinder walls with oil. Seals much better (higher compression and less wear) than trying to start dry. You'll want to wait about one minute after running the starter motor without starting to allow the oil to spread and then start the engine (without the stop).
Having said all that, your problem is still most likely electrical as posted above.
Guilty as chargedBut if he’s just getting a click he’s not turning the engine, so not “priming” in the sense you mean.
. He is not turning over the engine.Yes, check AND CLEAN all the connections. I'd especially suspect a bad ground.Thanks all. Should have been clearer. I meant priming the glow plug. Holding the key to the right for 15secs. Used to start right up after that. Now I am doing it 8-10x and just click. then when I let it sit for a few min, while I pray, it starts. Might be the prayer, might not.
All connections good at batteries. Will check starter connections. Or button connection.
I think he means holding the glow plug button for 15 seconds?A weakly engaging starter relay is almost always a result of insufficient voltage, bad connection, weak battery, undercurrent.
Routine maintenance 101 - when did you last remove, clean and reconnect all connections?
Also, why do you “prime for 15 seconds”? Should be unnecessary unless there is a fuel line leak.
He saidI think he means holding the glow plug button for 15 seconds?
If it's not crud on the connections, bad solenoid, worst case scenario take and have the starter rebuilt.Thanks all. Should have been clearer. I meant priming the glow plug. Holding the key to the right for 15secs. Used to start right up after that. Now I am doing it 8-10x and just click. then when I let it sit for a few min, while I pray, it starts. Might be the prayer, might not.
But he’s only getting a click, no turning. A glow plug issue wouldn’t prevent the engine from turning.Sounds to me as though the glo-plug is burnt out.
