I have a DC parallel panel patched onto whatever panel came with my 1993 Hunter Legend 35.5, and it is full of mysteries. Most recently, after replacing my batteries, I wasn’t getting DC power and determined the “house breaker” on the DC parallel panel was no longer working. As we were leaving that day and I couldn’t source a 100amp breaker to replace it, I settled for a 50amp and hoped for the best. Now, when plugged into shore power, the same house breaker trips and won’t stay on for more than a few seconds. I’m not using much amperage - why would it trip when connected to shore power?
I did notice that when I flip it, the voltage to the house battery goes up slightly from 13.2 to 13.3, volt and the starter battery goes up from 12.55 to 13 bolts before the breaker trips. And they settle back to 13.2 and 12.55 respectively. It seems the house parallel panel house breaker is the conduit for the AC charger to charge the starter battery, and the amperage drawn exceeds 50amps?
See image for the “house” breaker referenced.
