Install New Winches?
Kevy
Nov 27, 2018
48
Hunter 320 Nanaimo
Heya!
Our 2000 H320 is a great family boat, but sometimes the sailing leaves a bit to be desired (mostly due to operator error).
I'm considering putting 2 new winches on each side of the cockpit in the area that looks designated for such installation (picture attached). Currently we have only 2 winches next to the companionway - a 30ST to starboard and 16ST to port. It's a bit of a pain with the mainsheet and outhaul requiring the starboard and I think having 2 winches set back for the jib sheets would be nice.
2 questions - 1. Any thoughts/experience. 2. Is there an aluminum plate embedded in the glass at the pictured point to support a winch?
Rick D
Jun 14, 2008
7,193
Heya!
I know on my 40.5, in the manual, there is a diagram of a spinnaker option that shows the placement of winches for that application. It might be worth checking that out.
Likes: Kevy
Jan 4, 2006
7,438
I've got the same thing on the '99 H-310. You may be able to see an embedded plate in there if you can get a strong light under the mount by going through the overhead lighting below. Do this when it is dark outside and you will see an outline of a plate if one exists.
Another route is to drill a hole through the mount with a small bit (1/8") and check for aluminum cuttings. Fill the hole after with white gel coat if you have some from repairing spider cracks. That's if you don't find a plate and don't proceed with the install.
Likes: Kevy and RoyS
Jun 1, 2004
8,259
Wow, you have a 32 foot boat with NO sheet winches. Whoever ordered that boat new must have been super cheap. You definitely need a pair of primary winches in the cockpit near enough to the helm that you can tweak them and still have your hand on the wheel. The best deal is to keep an eye open for the West Marine/ Lewmar 2 or 1 sale. Someone here will know when the next one is. The Lewmar Ocean #40 would be a great size for your boat. WM sells it for $1499. You can find discounts at Defender, Maui etc.... if you don't want to wait, but the WM/Lewmar BOGO discount is by far the best. 5 years ago I bought 2 sets, a pair of single speed 15's for the halyards, and a pair of 30's for the primaries.
So you will have the 16 on the companionway for halyards, and the 30 for main and other uses. The you have the primaries in the cockpit for headshail sheets. Just go look at other boats.... any other boats.
You can put the winches anywhere you want. If there's imbedded plate, you can build a backing plate out of marine ply, or aluminum plate, or starboard.
Found in a practical sailor review of the H320.
Standard equipment is one two-speed Lewmar 30 and one single speed self-tailing winch, both on the cabin top. These are for trimming the jib and hoisting halyards.
While this minimalist approach to sail control may reduce the number of lines in the cockpit, as well as cost, we prefer the arrangement on our test boat. The boat was equipped with Lewmar 46 self-tailers on each side of the cockpit, augmented by Schaefer turning blocks located at the base of the arch. This arrangement places the jib sheets within reach of the helm; spinnaker sheets are led from the arch to the cabintop winch.
Aug 19, 2021
511
Hunter 280 White House Cove Marina
Yes and no.
Yes, I have the same mounting points on my H280. Yes, I have added winches there.
No, there was no aluminum mount or backing plate installed in or under my mounting points. I did read in numerous articles that Hunter did install the aluminum mount or backing plate under these locations not used from the factory. This is not my experience.
Oct 6, 2007
1,164
Hunter H30 1982 Chicago IL
Good decision. You absolutely need genoa sheet winches. I’ve never seen a boat like this without them.
Another way to determine if there is an aluminum imbed plate in the deck is to use a moisture meter. Any metal in the deck will cause a false 100% saturated reading.
2,366
I fitted 2 winches on the same location you shown. There should be backing plate within as its meant for spinnaker winches. One important point is orientation of the winch you put there. Make sure you mount with the removable component parts facing inside of cockpit (when drum removed). Mine faced outward and almost lost some parts as I remove it for servicing :( Kinda late to turn it around now as it was bedded down.
Likes: JBP-PA
@Ken13559 , some winches are designed to be oriented in a specific manner. The orientation is based on the gear design.
Andersen provides a single page guide regarding this issue. (See attached pdf)
Regarding the challenge of opening and servicing the many parts and not loosing them, I have used two methods.
First: a box with tall sides on the three outward faces. Cut a hole in the bottom. Fit the box over the winch and work on it carefully.
Second: is an old sheet draped around the winch with the folds leaning inwards toward your lap. When playing with those pesky springs you might drape some of the sheet over the top of the winch as a tent to stop the parts from flying about.
Patience and practice help when addressing this annual task. That said I have from time to time had to visit the local marine store to find a replacement that has chosen to jump ship.
Good luck.
Kevy
Nov 27, 2018
48
Hunter 320 Nanaimo
Great points, thanks. I think I'll recruit some close-by expert help as well as I'm a bit of a novice in this sense.
I'lll look you up when I adventure north and visit Ladysmith. Hopefully this fall.
chp
Sep 13, 2010
434
Hunter 280 hamilton
Yes and no.
I'm planning on adding combing winches this year. Looking at the Harken 20 ST radial. Curious to what size winch you added and did you run your jib sheets back to them. I want to be able to run the jib sheets from the helm and possibly a spinnaker in the future.
JBP-PA
Apr 29, 2022
711
Jeanneau Tonic 23 Erie, PA
At the end of the day, once you get your winches and drill the mounting holes, you will know if there is a plate installed. You can assume there is a plate for now and always get a backing plate later if necessary.
Aug 19, 2021
511
I had to open mounts in my cockpit. I went with Lewmar 16CST on each side.
Good morning @chp .
First, I want to say that it is your boat, and you can do whatever you desire with it to make it function for you.
Looking at the Hunter 280 design. It was not designed for a big foresail (jib). The sail plan relies on the larger Mainsail to drive the boat. The sail plan has the jib at 43% of the sail area (338 sqft) and 56% allocated to the Mainsail. When preparing a sail-plan, the designer considers the standing rigging/hull/keel/mast and space allotted to the skipper and crew. The smaller forces of the jib on the control lines allowed the running rigging to be located next to the companionway. This coincidentally supports the marketing of "Safety in all lines served from the cockpit." Optimal trim of the jib can be accomplished by keeping the sheets short and running along the cabin top to the bow end of the cockpit. This is not to say that owners have not put winches further back on the combing. Some have even placed large winches there at considerable expense with marginal functional improvement.
Regarding the Spinnaker. I suspect an Asymmetrical spinnaker would help drive the boat on broad reaches to the downwind. Depending on the conditions, a moderate-sized asymmetrical sail would be my suggestion. If you have one of the shoal draft keels, the rocker shape of the hull coupled with a large spinnaker could tend to create a broach risk as the rudder lifts out of the water. The mast and standing rigging are intentionally a lighter-weight design.
In light wind conditions that favour using a spinnaker, you want to be able to hold the lines and maintain trim control of the sail. For this purpose, I would run turning blocks at the location on the diagram. This puts sheets in the cockpit.
Enjoy your boat. It is a comfortable rig to sail—sporty and fun on the water.
Likes: Hello Below
