Hope I can get some insight into the issue I am experiencing.
A couple of seasons ago I upgraded our charging system to include a Balmar 6 series 150 Amp alternator coupled to an MC-614 external regulator, I also installed a SG-200 battery monitor system.
Everything was working perfectly until this spring when I commissioned the boat a couple of weeks ago.
When plugged into shore power the SG-200 shows the correct voltages and amperage charging curves from the onboard invertor/charger, but when on engine power the SCG-200 indicates the correct charging voltage (according to the MC-614 setup see attached) but negative amps, the higher I rev the engine the more negative the amps?
I have removed the alternator and checked the diodes and all is right there, which correlates to the voltages I am seeing on the MC-614.
I am guessing that I might have a bad temp sensor either on the alternator or the battery? which would cause the alternator to reduce output, but I am not certain on how to go about checking this, I would like to hear from the experts on this issue.
I did purchase the system from Rod at Compass Marine, I am hoping that I can get some information to help remedy this issue.
Thanks in advance
Mark
Thanks in advance
Mark
