Main track insert question
Apr 24, 2020
117
Hunter Cheribini 37 South Portland
On my 37C, 10" above the boom, the track is open on one side to insert the sail cars. The stop sits just above this which means when the sail cover is on, it sits 10" higher than it could be. If I move the stop down, I risk having the cars fall out of the track. This seems wrong. Am I missing a piece that closes the feed gap or something?
Dan
6,006
Oday 322 East Chicago, IN
On my O’Day 322, with a Z spar, my mast gate had a plastic plate that would close off the opening. It was riveted to the mast, but had a long hole in it, so it could move up and down the mast to open or close the gate.
Here is a photo with it open and closed.
I have since added a Tides Marine Strong Track, so I removed the gate.
Hopefully this gives you some ideas.
Apr 22, 2011
978
Rig-Rite sells them, but at ridiculously high prices.
You might try
Mastgates.com. Pretty slick concept. Here is a video of how to install and operate.
They do have a newer version that looks easier to install,
563
J-Boat J/99 Cobourg
I have a piece with tapped holes in the mast so I can screw the piece in after the main is raised.
Dan
Apr 24, 2020
117
Any chance you could post a photo?
This seems to be the answer whether I make when or buy one. I'm surprised it didn't come with something there for this.
Thanks!
Dan
10" higher for the sailcover never bothered me. If you do fit some sort of gate, make sure it is easy to open and keep open, because those sail slides have to come out when you reef!
Apr 24, 2020
117
That was another issue...now solved!! Thanks!!!
