Hi All,
I have a boat, it is a Dufour 34 feet, 1975.
I wanted to add a second winch so I can trim the spinnaker.
Right now I just furl the jib completely before raising the spinnaker and then re-use the winches.
It flies but I have never gybed and I could use the Jib to help lower the spinnaker better.
There is a base there in the back it has wood backing. I guess a second winch was an option the owner never took.
So question 1.
The big main Jib winch is Lewmar 43.
Do I put a Lewmar 40 or a Lewmar 25
Those were the two options in 1975
or do I just half it and get a newer Lewmar 30
All would fit the 40 with what looks like 1/4 inch.
Question 2.
The photo in Item 2, what is that for ?
What went over there ?
It also has backing.
Question 3
Do I add a pulley to the bottom of the stanchion or technically it is the pulpit , stern pulpit.
Will it be fine with the pull of the spinnaker line ?
Photo Item 3
Question 4
Do I add another cleat Jam Cleat to the New winch I am adding.
I assume it would not be best practice to share jam cleats.
I can't remember if there is backing but not too hard to add it.
Thank you for your time and happy sailing!
So question 1.
Question 2.
Question 3
Photo Item 3
Question 4
