3 Blade Prop Swap?
Apr 8, 2023
8
Catalina 30 Lake Champlain
Hi All!
Recently purchased a C-30 and will be bringing her from Lake Ontario to Lake Champlain via the Oswego > Erie > Hudson > Champlain canal systems soon... She is a '77 model with an Atomic4 engine. A beautifully cared for boat... super excited.
In our planning, I have been thinking that I may swap the 2 blade prop for a 3 blade before we begin the journey. My thoughts are:
1. This will be a long trek of about 10-12 days in canals and rivers and lakes, so perhaps an optimal cruising speed can be gained?
2. The 3 blade will pair well with the Atomic4 30hp - which seems to have more power than the 2 blade can apply according to the previous owner.
3. This is my 1st sailboat and I'll be navigating 30+ locks - thinking the 3 blade will give me more control when tight navigation is needed... especially in the rivers with more currents.
Anyone have experience with a similar config? Agree / disagree with my thinking? Any preference on props? This is a lake boat, and will likely remain a lake boat, is bronze still the preference?
There's a 3 blade on on the Cat Direct site... but only 1 option and I'm not sure about Pitch / Shaft diameter yet.
Lastly, I do understand that the prop will slow sailing speeds, but as this is my 1st boat, I'm not too concerned with squeezing out top speeds in the near term... would prefer better response to keep me out of trouble while I get comfortable.
Thanks for your thoughts!
Lets start out with a Welcome to the SBO Forum.
Congrats on your new to you boat and the adventures you are planning.
Props are an essential element of the auxiliary system on your boat. The enthusiasm of this "A beautifully cared for boat" should some times be peppered with the recognition once you begin your journey the boat must be ready to get you safely to the end. Inspection of the prop, shaft, shaft log, stuffing box or dripless seal, coupling flange, transmission, and engine should be accomplished with an expert eye for the age and condition of the components. If you are new to this, please have a quality boat mechanic assist you at these first steps. Help with and observe what is being done, and why. We have all learned this stuff from others who shared their skills.
Your question was one I faced in the refitting my boat. I selected a Campbell Sailor 3 bladed prop from West by North. ( Home - West By North )They are located in British Columbia. It greatly improved my boat performance under auxiliary power and did not greatly reduce my sailing performance (when compared to no prop on the boat).
Here are the old and new. It is all about design, size and pitch to match your engine/transmission.
Likes: dmax
dmax
Jul 29, 2018
1,203
Telstar 28 Buzzards Bay
The 3 blade prop will improve your power significantly - I had a C-30 with a 3-blade prop and it motored well, really bites in when starting from a stop or reversing to slow down. You could feel the drag when sailing though, probably lost a 1/2 knot or more over a 2 blade. If you go the 3 blade route, I recommend getting a Campbell Sailer prop over standard 3 blades, much more efficient when sailing: Campbell Sailer
7,262
2 blade vs. 3 blade makes no difference in power if both are well adapted to their job. Neither one is rated for better efficiency over the other. The engine is operated at a cruising RPM of about 85% and that's your power output with both props.
My advice is to not change anything that works until you have a year of use under your belt.
It grieves me something terrible to agree with @jviss so readily :biggrin:, but truer words were never spoken on the subject of props.
The only reason I changed from a 2 bladed to a 3 bladed prop was to get rid of the vibration of the 2 blades both aligning with the rudder slip stream at the same time. The new prop ran as smooth as silk after the change but nothing else other than the loss of maybe 0.5 Kts while sailing.
Likes: jviss
A three blade prop won't increase boat speed above hull speed, roughly 6 knots. A three blade prop will slow down the boat when sailing.
Now, about that long trip. Where are you starting? When do you plan to leave? Oswego to Waterford can be done in 4 days. To be sure they are long days. I've done it both ways from Fair Haven to Waterford and back in 4 days. There will be a little current on the Oswego River, but not that much and it is a relatively short canal, about 20 miles. Once past Sylvan Beach there is only one more uphill lock, the rest are all down hill and the current will be with you. The trip from Waterford to Lake Champlain is relatively short, but uphill, so there may be some current, I haven't done that section.
This time of year, most of the canal traffic will be north, you're headed south so the locks will be pretty empty, especially on week days. Wind in the locks is a bigger issue than current, in the locks there is no current. By the time you get out of Oswego (3 locks) you'll have the skills you need, by the time you get to Brewerton (lock 24) you'll be a pro.
Likes: jviss
I agree it's better not to change the prop before a trip like this unless there is adequate time to test it. Matching diameter/pitch to a particular design of boat is something of an art. It definitely takes experience. You are a bit covered if Catalina Direct recommends a 3 bladed prop for your boat.
Apr 8, 2023
8
We will set out from Rochester up to Oswego, which we hope to complete in 1 day... If all goes well, shooting to be queued up in Oswego for the day the canals open on May 19th. One unknown that I'm unsure how to time-budget for is the 33 Locks in the Route. I've got :30min per lock on avg as an estimate. Thoughts on this?
Love the enthusiasm. When and where will you take your mast down? Rochester to Oswego is a long long day. Figure at least 12 hours from dock to dock, if the weather is with you. Be prepared for cold weather, regardless of the forecast, the lake is currently about 45°, it won't be much warmer by May 19th. Consider stopping in Sodus Bay, roughly half way between Oswego and Rochester.
From Oswego you can easily get to Brewerton in one day. Then you have Oneida Lake. With a strong west wind Oneida can really kick up and be nasty. I lived on the lake for 10 years. Not something to do with a mast strapped down on the deck. If all goes well, from Brewerton you can make some where around Rome or Utica.
Estimating lock transit times is tough, too many variables. On the Oswego Canal the lock masters talk to each other, they will have the lock open when you get there unless there is opposing traffic. Further on, during opening week it could take longer, if your timing is unlucky. There will be a lot of traffic northbound, you may have to wait for that traffic to pass through the lock before you can pass through it. A lock can take anywhere from 20 minutes to over an hour. From Oswego to Waterford figure 4 to 5 days if all goes well.
If you haven't already, go to the Canal website and subscribe to the Notice to Mariners. That will give you the latest update on canal conditions and closures.
Apr 8, 2023
8
@dlochner - Thanks for the insights. One question - We plan to step the mast before departing in Rochester. You mention Lake Oneida can get pretty choppy... and not something to do with the mast strapped on the deck. I haven't researched passage through Oswego to Lake Oneida with the mast up. Is that an option?
Once the mast is down, it stays down until you reach Lake Champlain. The controlling height for the canal is about 20' from Oswego and east, it is lower to the west.. There is good information on the canal website.
If the boat has the mast up now, I would leave it up until you get to Oswego and unstep it there. I am sure some have done the trip from Rochester to Oswego with the mast down, I wouldn't do that unless the mast was already down. With the mast up the boat is more stable and you will be less constrained by weather. There is a weather buoy near Rochester that reports conditions on the lake. Currently the water temp is 39° and the air temp is 39° with a S wind. Tracking the weather patterns for the next couple of weeks will prove to be informative.
Likes: Dudenhoeffer
Apr 8, 2023
8
Yep - All that makes sense - And thanks everyone for the feedback on props and advice of holding off on the swap. We have opted to stay with the 2 blade prop for the season and will revisit next spring. Cheers! - D
Ward H
Nov 7, 2011
3,786
Welcome to SBO and Welcome to Catalina 30 ownership.
I agree with other posters about waiting to get time on the boat and learning about it's handling characteristics before making costly changes.
If you do want to investigate a 3 blade prop I strongly suggest you skip CD and work with a prop shop. CD has several props listed for various engines and transmission ratios but not an Atomic 4 30hp. I don't know if they run your specs through their computer and then have it pitched for your motor or they have a stock of various. And not all C30s are built the same so measurements from maybe a 83 C30 may not be the same as your 77. A good prop shop will need various mesaurements to ensure they recommend the correct size and pitch prop. While I like CD for many reasons I wouldn't trust getting the best prop for my boat from them. Also, their props carry a premium price tag. I have a quote from West By North which is about $250 less than CD.
As mentioned by @jssailem and @dmax, West By North is good shop to go with.
Sounds like you're planning a fun trip. Enjoy!
8
Wanna circle back and thank everyone for the feedback / guidance!
We stuck with the 2 blade prop for our 400 mile lake / canal / river journey. All went fairly well... although I did have to reconnect the steering cables day 1 (good to know where the emergency tiller was! Will post the Navionics tracks for everyone's amusement) and, the trans cable mount came loose day 7 at 3am when the anchor dragged... and the trans cable helm linkage was a mess... and... and... :) Still - it was an amazing trip!
Anyway, one thing I did notice is that there was ALOT of clattering from underneath and visible vibration in the prop shaft if we throttled even half way. So we had quite a slow go of it... 5 knots seemed about as good as she would get without pushing her too hard.
So, I'm guessing the Cutlass Bearing is shot? I did tug on the shaft when it was out of the water and didn't feel much play. But I'm not sure what else to look for. Engine mounts seem ok... the issue seems to show at the stuffing box / shaft. Pull her out and do the work? Is there a better way to diagnose this?
Sounds like a good trip. It could be worth checking the prop shaft alignment. At least that can be done in the water and it could explain vibration.
When the water warms, you may want to dive under your boat and assure you did not pick up any debris as you transited the canals and rivers.
Shaft alignment (as David suggests)
Unbalanced prop (some one bit a chunk out of one blade)
Fishing Line/ rope / garbage bag on prop or shaft
worn cutlass bearing
loose shaft strut
Motor mounts worn
There is a quick list of possibles. Try the easiest first.
Likes: Dudenhoeffer
Apr 8, 2023
8
Hi @all - We have determined that the prop shaft is actually bent. There is a visible wobble at low RPM at the stuffing box. Couple newbie questions that I didn't find answers to searching around:
1. Is the original prop shaft material Bronze?
2. Our boat is on Lake Champlain VT, anyone know of a NE shop that I can work with to straighten then shaft?
Thanks for you insights!
Don
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
Don
Straightening a prop shaft is something any competent machine shop should be able to handle. I'm assuming you're going to remove it yourself, or have the boatyard do so, and bring or ship it to have it repaired.
I imagine the boatyard would know local shops.
Failing that, I found these guys near me:
Fleet Propeller
1. Not likely. Steel alloy like Aquamet would be my guess. Certainly that is what you would be looking for to replace the shaft.
2. Bent shaft means you get a brand new straight shaft to replace it.
Here is one site that might be able to help.
