Alternative to bimini
Apr 24, 2023
23
Hunter 28 Rochester, NY
I want temporary shade/rain protection in the cockpit but don't want a bimini. Looking for something that's easy to put up and take down. Any suggestions?
Thanks
Jun 14, 2010
2,477
While underway? No other suggestions. Bimini is best.
At anchor? Boom tents, umbrellas, awnings.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Boom doesn't extend over the cockpit.
Oh, well, you can make some kind of rod that attaches to the end of the boom, the aft end of which is supported by the backstay or a topping lift, and pitch a cloth over it. You could even fancy it up, make one out of sunbrella.
Apr 24, 2023
23
Thanks, that's a great idea.
7,699
Alden 50 Sarasota, Florida
Depending on where the sides (of a boom tent) are attached, the useable space under it can be very small. I tried such a thing on a 27 ft boat we once had and found it effective in the rain.
Likes: skob1014
Jan 7, 2011
5,943
Oday 322 East Chicago, IN
I have something similar to this.…
Sport-Brella Premiere UPF 50+ Umbrella Shelter for Sun and Rain Protection (8-Foot)
I don’t think mine is 8’. But I can set it up in the cockpit, tie out the edges to the rail, life lines, etc and get some shade.
Catalina 36mkII Alameda, CA
On my Catalina 36, I installed a fishing pole holer to the pedistal guard. I then purcahsed an inexpensive 9' round umbrella and slide it into the holder. I have found that the umbrellas with the wire type arms are more flexible for my use.
It's not perfect but it does give a bit of sun protection. You may need to cut down the pole as needed.
Sep 7, 2022
70
Captiva Yachts Sanibel 18 Lake Wylie
Agreed. Can anyone speak to how practical it is to sew Sunbrella with a regular home machine? Or would you absolutely need an industrial one?
Mar 8, 2019
111
ODay 322 Bodkin Creek, Chesapeake Bay
I sew it with an old 1970s Kenmore. Works fine till the seams are more than about 1/4 - 5/16" thick. Pick up a yard at a chandlery and give it a try.
Aug 2, 2009
651
Catalina 315 Muskegon
On my Catalina 315 I was able to sew up a flat awning that zippers onto the aft portion of the dodger, and extends to the split backstay. The aft end of the awning has a pocket going all the way across that holds a wood stick...3/4" x 2"...the width of the awning. The wood is what attaches to the split backstay and provides an even pull on the awning.
The advantages of the awning are:
- It's only up when we want it. Not when we're getting out of the slip, putting up sails etc.
- It's the height of the dodger, so it's lower than a bimini. The lower the canvas is, the better it blocks the sun. More shade.
- It takes about one minute to deploy
- Provides rain protection, so at night we can deploy it, and have the screens in the companionway
- Rolls up around the stick, and stows easily in the aft berth area.
- You avoid the extra "plumbing" of a bimini....the tubes that support it and terminate on the deck.
- The aft stick can be adjusted lower in the situations where the setting sun is on the stern, cooking us
- It's a lot cheaper than a bimini. I was able to make my own with my 1972 Kenmore home sewing machine.
Disadvantages:
- Can't stand under it.
- It ends at about the steering wheel
- Being flat, it may not shed rain as well, but the aft stick can be adjusted lower on the backstay to create a greater slope.
An awning like this won't work with every boat. Depends on the relationship of the backstay, etc.. And it's not going to work for every sailor. We're in Michigan, and mostly daysail, so with the way we use our boat, it's vastly superior to a bimini....for us.
One more thing about a lower awning creating more shade. Imagine you have a tarp 4'x 4' one foot over your head, and how much it will protect you from the sun. Now, raise it 3 feet above your head. You've lost most of your shade, and if the sun is at an angle, the shade patch might miss you altogether. Lower is best.
Jan 7, 2011
5,943
I bought a Singer 4411 Heavy Duty sewing machine and it sews Sunbrella just fine. I can sew several 4-5 layers with a denim needle just fine.
Likes: skob1014
Apr 24, 2023
23
You really need a shade system to be used continuously, like a bimini. Skin cancer, especially melanoma, is no joke. :cool:
Thanks, I do take that danger seriously. Even with a shade device I will be completely covered with long sleeve shirt, pants, and wide brimmed hat.
Likes: BigEasy
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
On my C&C27 I had a canopy that zipped onto the dodger and was held up by a cross pole that fastened to the backstay and a tie near the middle. The boom on that boat extends quite far aft so I fasted it to the boom but it could be held up by the main halyard or some type of topping lift, even a lanyard attached to the backstay. There were also zip on side curtains that draped over the lifelines and were tied to the toe rail for additional protection when needed. Handy to block the evening sun as well as for keeping the rain out of the cockpit.
I have seen canopies on boats that do not have a dodger with a cross pole at the front as well, supported by the boom.
I have sewn a main sail cover with an old White sewing machine I picked up at a thrift store for $20. It worked very well.
May 29, 2018
676
Canel 25 foot Shiogama, japan
Measure up some light shade clothe.
That is the stuff that lets the wind pass through.
Sew back two edges so they will take plastic electrical conduit.
Grommets on each corner and in the middle each long edge.
Light lashing lines on each corner.
Mine are to length with cheapo plastic hooks on the end.
A correct length of smaller diametre tube (2/2 inch) fits across the centre grommets to take slack and prevent fluttering.
2 minutes to set up or take down.
