In the process of replacing my PSS bellows, I had to replace the coupler set screws as they got mangled in the removal (they were quite seized) - they did finally come out, but are no longer usable, so I got some used replacement set screws (they are exceptionally hard to find in Bellingham WA for some reason). I am wondering if I should use antiseize on them or loctite instead. I will install seizing wire, but don’t want to have issues with removal next time. I also don’t want them coming loose during operation.
Also, the coupler mounting bolts (to the transmission mounting plate) were not very tight when I removed them. I could rotate each bolt/nylock by hand. Does anyone know how much the 4 mounting bolts should be torqued? Also, how much the coupler set screws should be torqued?
Much thanks.
Much thanks.
