Well even
@SailorShaggy slightly
Starboard Bent Wing might help against "Prop Walk"
Facts I learned from
Hunter Experts about my bent wings.
1) Weight of the Keel is needed to keep the Gunnels out of the water on a beam reach. [7700 lbs]
2) Shape is for sailing with minimum Drag [Like the golf ball]
3) Wings were designed by Hunter Naval Architect. Called shoal draft. Deep draft keels have no Wings.
4) Once the wings are reshaped, you fill the dimples with a fairing compound. Then use Bottom Paint.
The bent wings BEFORE picture in my post #7 above.
Even though the keel bottom has not been painted yet [guess why not], my now picture.
My repair yard can contact your yard on the "How to Fix the Lead Keel"
___________________
The rudder has an easy solution
Great news! Bob Walker at Foss Foam is great to work with.
Smooth Sailing soon on your Repaired Lead Keel.
Jim...
