Hi All,
Noob questions so bear with me.
I replaced my Jib sail to do maintenance on the one that was on the sailboat.
I have a furling jib,Harken.
The forestay has a luff foil on it.
The Luff foil has two tracks so I can feed the sail in either.
The first question, is which track do I use?
The second question is assuming there are two tracks in place so I can take one sail down and raise another at the same time.
How do I do this ?
If I lower the current sail, the swivel at the top will come down and prevent the other sail from going up.
Is it just so I can "prep" the other jib a bit, then lower one jib, switch the shackle from old jib to new jib, then quickly raise ?doesn't seem like it would save that much time.......
The third and final question.
Should I replace the shackle at the top swivel with a Twist Shackle ?
Thank you
Saar
How do I do this ?
Thank you
Saar
