Ice Box Lid Hold Open
Apr 17, 2013
174
Catalina 310 57 Pompano Beach, FL
I recently purchased a ice box hold open from Catalina Direct prt# Z4237 it had been used on the Catalina 350. I tried it on my 310 and it is too long. Would love to hear some suggestions on what other 310 owners have used.
Thanks,
Mark
Apr 17, 2013
174
Thanks,
Mark
I should have been a little more specific it is whatever you use to hold open the ice box lid and I know your left or right hand will work fine.
Jan 7, 2011
5,467
Oday 322 East Chicago, IN
Thanks,
Mark
Can you move the attachment points so the spring fits? I am just guessing, as I don’t have a Catalina. But I did buy a spring thing to keep mine open, and I assume I just set the attachment points on the lid and the box at the appropriate distance to accommodate the spring?
Or does your Catalina use some other kind of device?
Jan 4, 2006
7,178
Don't know where the Catalina 350 came from but as Greg has said, why not re-position the lower plate and seal off any unused holes :
D
Deleted member 117556
I purchased these on Catalina direct and installed them on the fridge and dry storage lid. They work well and were a great addition.
DaveJ
Apr 2, 2013
474
I have wanted these supports for a long time, could never find them or saw them and had no way of knowing if they would fit. Would you have a part # from CD?
I see you mounted them differently (opposite directions), what was the reason?
Also, the insulation on the fridge lid, does it make a difference?
Sorry for all the questions, but these look like easy upgrades.
thanks
Cheers
DaveJ
Apr 2, 2013
474
Looks like the angles of the mounting brackets are different, may need an additional bracket to make these work.
Cheers dj
Oct 3, 2011
832
Here is what we used from West Marine: It has worked really well...Sorry about image size
Hatch Arms image number null
Likes: rpwillia
D
I actually would love a better picture of that towel holder location and mount:)
See attached the key is having the shelf where we store drinkware. I thought that was a standard item but have since learned it is not.20230412_081848.jpg20230412_081544.jpg20230412_081524.jpg
Likes: JRT
JRT
Feb 14, 2017
2,054
No, I've never seen that before on any 310, we have 3 310 and a 315 in our marina. Looks good for sure, but too much of a project for my use if the boat. If I can make my retirement plans work in 5-6 years maybe then lol.
D
Ours came from the factory with that shelf. Yet another one-off for hull #1
