Hello,
tomorrow I'm tackling the installation of two 100W flex panels. I've looked around and cannot find where to put the 2 MPPT charge controllers. I plan on installing the flex panels on the bimini. Run the wires along the two back stays. Use glands to put a hole close to where the backstays are connected to the transom. Heat shrink the backstay to keep it organized and look nice. Bring all the wires to the starboard side and work my way through the quarter birth, head, battery compartment. I was told not to keep the MPPT in the same location as the battery compartment since by batteries are acid. I was planning on putting a hole in the other starboard settee, and then coming back with the 2 wires to the battery compartment. Any thoughts on this? Any pictures on where the controllers are installed.
Thank you!
Giorgio
Thank you!
Giorgio
