can you mix winch and winch handle brands?
dLj
Mar 23, 2017
5,233
Ya gotta read the fine print... Plus, that doesn't even come with a battery, you have to buy it separately and if you go look for it - that does not appear either...Really not sure what's going on with these...
Have you contacted Milwaukee about availability? Last summer I was looking for a Bosch sander and had a similar message from every vendor. I contacted Bosch and they confirmed the sanders were not discontinued and provided a date when the sanders would be available. Apparently these tools are not in continuous production.
Ward H
Nov 7, 2011
3,843
Selecting the 'best' handle really depends on your boat and the type of sailing you do. On my boat, this is my favorite handle
I'm agree with Barry. The Lewmar 10" one touch palm grip handle works very well for me and guests. No issue locking/unlocking. I leave the handle in the winch for easy and quick adjustments. I also always leave the handle pointed outboard to prevent someone from getting jabbed by it in the event they sit down hard on the cockpit seat.
dLj
Mar 23, 2017
5,233
Good thought - never occurred to me. I will shoot them a message.
dj
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
I would expect the 3/8" rechargeable Milwaukee would be a better fit for operating a winch on a sailboat than the 1/2" . The horsepower that is brought to the winch is only used in the last half turn if needed and the need for the electric is moving those arm joints around in circles a lot and fast. I based this opinion on carrying a 1/2" corded Milwaukee around job sites for hours on end and switching back to the 3/8" rechargeable Makita at the earliest convenience. Part of the reason was that the Milwaukee could lift me off the ground momentarily but the Makita could not. Back in the day I could handle that but today I would not want to.
Jan 7, 2011
6,013
Oday 322 East Chicago, IN
I have the M28 1/2” right angle drill I linked to (sorry @dLj….didn’t see it was out of stock).
It is relatively heavy, but once in the winch socket, you dont need to hold it up. It is long enough to be able to keep it from torquing around on you, you can. Lean it up against your leg or whatever if needed.
I burned up the switch on mine trying to use it to crank someone up the mast…so don’t do that:banghead: I put some over-sized primary winches on my boat. And ran the halyard to the primaries. With the reversible drill, I thought I could crank the winch in the low gear and crank someone up the mast…got them to about the spreaders before things went south.
I am going to replace the switch and try to get my “power winch” back in business before spring.
The best part about the drill is the speed in which it would crank up the sail…especially when single-handed, it was no effort to get the main up in a hurry.
6,013
Oct 6, 2007
1,180
Hunter H30 1982 Chicago IL
I think they’re pretty much universal. I have three different locking winch handles of various ages on my boat and they all fit my Harken winches. The two oldest ones worked with my old Barient winches. The newest is a telescoping West Marine brand for the cabintop winches under the dodger. No floating handles and I haven’t lost one overboard yet (Hope I didn’t just jinx myself.), but I would never want to be without a spare.
Jan 7, 2011
6,013
I got the $70 switch for my Milwaukee M28 drill today.
Wired it in, plugged the battery in, and it works!
Note the beefy winch bit that replaced the drill chuck.
Can’t wait to crank the main up with the power winch this year!
Likes: Tin Kicker
Be careful Greg... that bad boy might winch the sail up before you see it is caught on the spreader... Or the halyard is jammed.
Good luck
Jan 7, 2011
6,013
Good luck
I put a 2-speed winch on the cabin top, and yes, it will crank the sail up fast. But what is really nice is that I can get the sail past the lazy jacks quickly while holding the boat into the wind.
It is fast and convenient.
Just don't catch the Lazyjacks when a gust flips the sail in mid hoist.
You maybe getting that new sail you were talking about sooner than your budget planned.
Jan 7, 2011
6,013
Got the new main already….with Tides Marine Strong Track, so she goes up nicely.
But I do have a new 135 Genoa on order to replace my aging 150…. Can’t wait until spring!
You and me both. It is 19º F (-7º C) outside this AM. Even the birds are complaining about snow and frozen worms.
I went out a little after daybreak to put out the Humming bird feeder (I brought it inside last night so it would not freeze solid. They hate popsicle sugar water) and the resident was already buzzing about the deck complaining.
May 16, 2015
114
C&C 37 28127 Port Madison, Washington
I'm strongly considering the M28 for winching. However, I'd love to be able to trade out batteries and use the same charger as my other Milwaulkee tools that are 18V. Would the M18 angle be underpowered for winch uses?
Jan 7, 2011
6,013
I am not sure. I have the M28 right-angle drill, and Tides Marine Strong track on my O’Day 322. I also have an upsized 2-speed winch on the cabin top. I can raise the sail pretty fast, but as it get up to the last 1/4 of the mast, I have to reverse the drill to use the low speed winch to get up the last 10 feet.
