Thank You, how do I get a cross reference for the Kubota# ?If you know the corresponding Kubota part number: Messicks | Your home for New Holland, Case IH, Kubota & More...
If not: Largest Sailing Supplies Store in West Michigan- Torresen Marine, Muskegon
Thanks for all of the info I found a website www.discountmarinesource.com which had the universal parts I was looking for.The trick is to get the Kubota block #, Figure out which tractor it fits also helps. I used to get my parts at the Kubota tractor dealer. They cannot look up marine parts but if you give them a part number they can order it. I needed a rebuild kit and a head that I bought from Kumar Bros in NJ. The gasket kit did have an incorrect O-ring- had to use the old one. My block was a Kubota D-950
Bingo. Another source can be a local industrial diesel repair shop. A few years back when my M-25XPB injector pump failed (instant shutdown, no hesitation or sputtering) the marine distributor wanted over $1500 for a rebuilt pump, the local shop had the parts in stock and did it for $540 parts and labor, and did it in 2 days.M-25XPB - Kubota D-950 - D1005.
I've got to a point that I just go to the Local Kubota dealer with the actual part and they have so far been able to match the parts. The BIG plus it is usually a 1/3 of the price.
Sorry, I just did an image save and changed the title, so I don' know where it came from.Good day PlaneTom .......... any chance of getting the URL address where you picked up the Kubota engine Data sheet.
Cheers
2 Old Pirates
