Hello, I wonder if any of you can help me figure this out.
I have a water heater Quick BR 23 12 S (1200 W) in my Beneteau.
It has suddenly started to make the mains circuit breaker in my boat trip. This happens every time the heater is turned on.
I have tried diagnosing what the problem is.
Is it the water heater?
Thank you!
- The answer seems to be NO. When I plug the water heater directly to the land electricity (without going through the boat’s electrical system), it works just fine. It draws 1200 watts, as expected, and the water is heated as expected.
- Well, the answer seems to be NO. When I plug heavier loads (over 3000 Watts) to the very same power outlet, the breaker does not trip. It only trips with the water heater. The boat’s electrical system seems to be somehow “allergic” to the water heater only.
- I set in a new breaker just in case. Same behavior. It only trips with the water heater.
Thank you!
