This sounds like a crazy idea but since I have the mast step torn apart this would be a good opportunity. Other parts of the cabin top have rot as well even though you cant feel it when stepped on. I was thinking about getting some semi flexible tubing such as a brake line or copper tubing to use like a syringe to inject epoxy. The tubing can be fed through the open area of the fiberglass (mast step) to areas normally unreachable without tearing everything apart. Thoughts?
