I have my mast down this winter for general maintenance and have the spreaders at home to clean up. I'm curious what folks use for that? The tape goo seems to be coming off slowly with goo-gone.
I'm also looking to replace the boots that go over the spreader tips. The original ones look like they never were the right size. See pics attached. I was thinking maybe the leather velcro ones would fit better like these? https://www.amazon.com/dp/B07WXS9C49?ref_=cm_sw_r_cp_ud_dp_YN33WRH1TZGR9MRJW8QV
I know CD sells the leather kits you lace up, but since the boat yard will be stepping the mast without my presence, I wanted to keep things simple.
Any other maintenance recommended while the mast is down? Standing rigging is fine. Halyards still have a few years left in them. The boat is fresh water only. Not sure its worth replacing the mast mounted lights with LED since I don't really sail at night? VHF coax looks fine and the antenna and windex are fairly new.
The powered TV antenna works fine, but is showing signs of UV damage. Not sure there are replacements for this model of antenna (see pic)?
thanks!
thanks!
