C310 Spreader boots, cleaning and masthead maintenance?
Apr 19, 2020
80
Catalina 310 Kenosha, WI
I have my mast down this winter for general maintenance and have the spreaders at home to clean up. I'm curious what folks use for that? The tape goo seems to be coming off slowly with goo-gone.
I'm also looking to replace the boots that go over the spreader tips. The original ones look like they never were the right size. See pics attached. I was thinking maybe the leather velcro ones would fit better like these? https://www.amazon.com/dp/B07WXS9C49?ref_=cm_sw_r_cp_ud_dp_YN33WRH1TZGR9MRJW8QV
I know CD sells the leather kits you lace up, but since the boat yard will be stepping the mast without my presence, I wanted to keep things simple.
Any other maintenance recommended while the mast is down? Standing rigging is fine. Halyards still have a few years left in them. The boat is fresh water only. Not sure its worth replacing the mast mounted lights with LED since I don't really sail at night? VHF coax looks fine and the antenna and windex are fairly new.
The powered TV antenna works fine, but is showing signs of UV damage. Not sure there are replacements for this model of antenna (see pic)?
thanks!
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
View attachment 212089 View attachment 212090
View attachment 212088 View attachment 212087
thanks!
Was that TV antenna mounted up high on the mast? I have one just like it, but I keep it stored on the cabin with a long length of cable… when I am off grid (no cable TV), I just lay it on the deck.
I wonder how much better my reception would be if I raised it up on the mast?
Apr 19, 2020
80
Yes mine is mounted on the masthead...
Likes: Tally Ho
Clydo
May 28, 2013
371
Catalina C310 SF Bay/Delta
Wonder where could get antenna like that?Haven' had much luck with others.
Clyde Thorington
C310 #245
I LEANTOO
San Jose, CA
JBP-PA
Apr 29, 2022
838
Jeanneau Tonic 23 Erie, PA
Goo-gone, soap/car wash and water are all I would use. Any abrasive to clean the spreaders will remove some of the anodizing and oxidation that protects the aluminum underneath.
You can use whatever spreader boots make you happy. Lots of people like the traditional leather look, some like the simplicity of the plastic boots.
Do make sure your spreaders are reattached to the shrouds securely and at the correct angle, tilted slightly upward to bisect the angle of the shroud.
298
Catalina 270 Rochester, NY
Go to an auto parts store paint department and buy some 3M adhesive remover.
Likes: CowboyWay
May 2, 2012
276
Catalina 310 Toronto, Ontario
I've been using good old acetone on the spreaders. Works well. Every so often I use a buffing paste to bright up the aluminum.
80
nothing else seemed to work except for this to get the really dried old adhesive off. I used a fine scuff pad with it.
80
What about replacing the anchor light ? There's a good 10± AH per night to be saved when on the hook.
I haven't opened mine up yet, but I'm curious if others were able to simply replace the bulb with a LED module if so do they have a specific part in mind?
JBP-PA
Apr 29, 2022
838
Yes, you can get LED bulbs to replace most every old style bulb. Marinebeam.com will have it. Amazon will have cheap ones too, but for an anchor light, your better off with the higher quality ones.
Likes: CowboyWay
