- Oct 22, 2014
- 24,938
Hello Noah.
I do not have your boat.
Setting that aside, the concept of mast steps is universal across the many manufacturers building boats with mast steps.
It is basic thinking/engineering regarding the problem.
- There needs to be a solid strong compression post
- The deck between the compression post and the mast step must be solid and not allow moisture to penetrate
- You need to have a clean and proper mast step for the mast base
- You must design a proper method of wires and equipment to penetrate the deck in a water tight technique
