Stain for Hunter Sailboat Interior
May 7, 2012
19
Hunter 30T 1 GA
Does anyone know what stain was used in the interior of Hunter Sailboats in the early to mid 90's and where can I get it?
Jan 4, 2006
7,268
For 1999, I can tell you there was no stain used on teak paneling. I have done small alterations and repairs and have re-finished the original paneling with the same teak oil I use for annual application.
If you are installing new solid teak or paneling, remember nothing is more variable in colour that teak. Stain it darker but not vice versa.
7,438
Alden 50 Sarasota, Florida
Hunter did use a specific wood treatment in those days but I can’t recall the brand. Discussion about it can probably be found in the archives here.
May 7, 2012
19
Hunter 30T 1 GA
Hi thanks for the responses . I am doing some miner repairs, not using teak, Would like some kind of stain that might help blend in the small repairs I’m doing with what is there. Doesn’t have to be exact.
May 7, 2012
19
Hunter 30T 1 GA
using some oak and white pine. It’s just for small trim piece replacement and staining some existing where I needed to do some sanding
Jan 4, 2006
7,268
Question #1. Are you doing paneling or solid wood working ? Two different worlds of treatment.
Hunter used only teak oil on paneling and "something" on the solid teak which can be replaced by semi-gloss varnish and look identical. Hunter's choice of finish for solid wood was probably based on a fast drying finish for speed.
For Solid Woodworking. You're going to use a substitute, you'll have to watch the wood you use. Once tried disguising a hidden piece of oak (in a cupboard) as teak. Got the colour right but the wood grain looked terrible destroyed it. Into the fireplace pile. Maybe try birch ? Pre-seal with spray on lacquer (like Krylon) before adding any stain for more even staining. Lots of experimentation required. In the end, it's just a waste of time unless your a professional finisher.
However, you'll save yourself a ton of grief and achieve perfection by using real teak for solid woodwork. Substitution never works. For small jobs the cost is not an issue. Teak is not hard to find in specialized wood shops. Certainly much easier than finding birch. Pick through the pile to find the material that best matches your existing material as the colour of solid teak varies from light straw to dark brown. Finish the wood with #220 paper, and apply three coats semi-gloss varnish.
For Panel Woodworking. You'll have to find a less than full sheet of teak plywood. Can be expensive and rare. Finish ONLY with teak oil.
May 12, 2004
1,505
If the teak interior hue is dark like mine, a '77h, try rosewood stain. I needed to stain some minor woodwork and it matched almost perfectly. Of course, if your woodwork is more blonde I'm at a loss.
Jan 4, 2006
7,268
On my 2002 356 I was referred to the Mohawk line of products.
This is what you would have been referred to for repairs:
Same thing as I use (and finally remembered) :
I'm sure they're both the same thing and do a good job.
They're linseed oil, petroleum distillates, any anything else that's toxic, for teak surfaces but contains no such thing as oil which is extracted from teak.
