hunter yanmar
Mar 22, 2022
78
hunter legend nj
Hi Guys i am new to this an purchased a 1987 hunter 40 ft legend
How can i find out what size yanmar engine it has ??
Back in 87 did they all use the same size yanmar
Nov 6, 2006
10,257
Usually a plaque on the engine somewhere .. usually on the front gearcover ..
There should be a plate somewhere on the engine with the horsepower rating and model. There might be another one on the transmission with its model, gear ratio, and fluid type.
May 9, 2020
162
Hunter Legend 37 Harrison Twp, MI
From the ~1987 general Hunter Legend owners manual... but considering the age, should still confirm the plaque in the engine... it could have been swapped at some point.
Likes: kloudie1
Mar 22, 2022
78
hunter legend nj
As i read the chart listed it say a 40 ft hunter should have a Yanmar 4 J H S E Diesel
I have tried to search for a manual an only come back with a Yanmar 4 J H 5 E Diesel
CAN IT BE THE SAME ??????
May 9, 2020
162
Don't think they are the same.
The JH family starts in the 80's... and has evolved JH2/JH3/JH4/JH5... with the JH5 starting in ~2010.
I'm not a Yanmar expert... but I think you'll be looking at 4JH-E manuals... I don't know why the "S" is there... perhaps it meant shaft as opposed to saildrive... don't know.
You really need to get a picture of the plaque on the engine to be sure.
sorry can't be more help!
MFD
Jun 23, 2016
306
Hunter 41DS Pacific NW USA
As others have said - there will be a plate on the engine (somewhere). That is by far the most accurate way to find out exactly what you have, along with the serial number. For example - my 2009 Hunter 41DS has a Yanmar 4JH4AE.
Your transmission will also have a model and serial number as well. This is important to identify so you know whether it is recommended to keep it in neutral or reverse when under sail. And what kind of oil, etc ;)
Jan 7, 2011
6,018
Oday 322 East Chicago, IN
In another post, you said it was a 3jh40 yanmar…
Have you looked at the engine?
You can also count the fuel injector lines to see if it is a 3- or 4- cylinder engine.
Mar 22, 2022
78
hunter legend nj
Hi Greg sorry that was wrong I was just there an it differently has 4 fuel line going in to it
so it would be yanmar 4jh?? seen to tag or model on it but will look again next week end when i am back to it
