Seized Halyard Deck Sheave Bolt
If you blow the hole in the aluminum plate, you can re-tap and thread one size up.
I keep one of these in my boat tools and have ended up using more than a few times.
Likes: LloydB
Jan 4, 2006
7,771
is most likely to happen when the two fasteners expand/contract at different rates
It's most likely to happen when the hole in the outer material (in this case the aluminum plate) expands more, than the diameter of the SS bolt.
However in this case, the coeff. of linear expansion of the aluminum is greater than the coeff. of linear expansion of the SS which complicates things. You can blame @kloudie1 for this little wrinkle.
If done correctly, the bolt will be looser in the hole.
Likes: kloudie1
Jan 4, 2006
7,771
If the hole was enlarged in the fiberglass, filled and tapped, would it be strong enough for most deck hardware?
Wouldn't be strong enough to hang a dish towel on.
Where a Hunter gets the strength without nuts and a loading plate on the opposite side of the FG is with the buried and tapped aluminum plate between the layers of FG.
Likes: rgranger
Right!
You need to tap a larger size into the aluminum plate
QCI
Jan 30, 2014
31
Hunter 25.5 Bradenton
Got it out! thank you all for the help!
I used WD Specialist Penetrant over the course of 4 days. Applied it in the AM and the PM. Then used the manual impact driver that rgranger suggested. I marked the screw head with a Sharpie to see if it was turning. It took time & patience but it worked. I will use anti-seize lubricant when I reinstall. And a new bolt. Thanks again!
Also, ya gotta give me props for using the word sheave instead of pulley.
4,690
Catalina 30 MKIII Chicago
Patience is key! I read of one guy that had a seized antique engine. His plan was to fill all cylinders with penetrating oil and get them to move 1/8" once a month. He predicted it would take him four years at this rate!
May 29, 2018
687
Canel 25 foot Shiogama, japan
Hi QCI
Thanks for coming back with your result.
Will help someone else out down the road.
gary
