I'm re-wiring my 1983 catalina 27 and would like to relocate the electrical control center. That would be the main battery switch, circuit switches/breakers, bilge pump switch, and associated buss bars. I would like something hinged so I can get into the fuses and wires as I gradually swap out the existing wiring more easily. I'd also like to get it a little higher, although that's not as important as the hinged opening system.
The question is: where are some alternate locations people have used? I've considered 1) the former alcohol range location (but might but a range back there someday) 2) in the bookshelf type area behind your head on the port bunk 3) where there is currently a sliding cabinet in the galley. All have pros and cons and I'm wondering what other people have come up with.
thanks.
thanks.
