Was in a race recently and received a complaint and thought I would post it here. Other boat felt I needed to move out of their way as I was the windward boat. My response is I gave them room and sailed my proper course and did not inhibit them. Situation was we had a nice wind of 8 knots from the South-SouthEast. The course was a triangle with the start just off the marina to the South with the two other ends of the triangle being power pole B and D which we had to pass to port. I reached power pole B first and rounded it and the other boat came behind and was leeward of me. I sailed a direct course to power pole D and then turned upwind and ran as far as I could before tacking. To me it was fun as the other boat was the faster boat, but every time they tried to pass me they hit my wind shadow, lost speed and fell back. I did not attempt to do anything but sail the most direct course to the next mark. The other boat, not the captain, started complaining that since they were the windward boat I was supposed to give them room. The attached graphic shows our course.
My interpretation of the rules are below with the actual rules below that.
11. I kept clear and sailed my proper course.
12. The other boat at times was clear astern, especially after hitting my wind shadow.
14. We had no contact.
18.2.1 They did give me room and I made a super smart turn around the mark and immediately beat hard up into the wind. The other boat did lost some ground and eventually tacked behind me (the oncoming shore also likely made them nervous).
19. The other boat did give me room so no problem there.
I went through the RRS and feel the following are relevant.
11. ON THE SAME TACK, OVERLAPPED
When boats are on the same tack and overlapped, a windward boat shall keep clear of a leeward boat.
12. ON THE SAME TACK, NOT OVERLAPPED
When boats are on the same tack and not overlapped, a boat clear astern shall keep clear of a boat clear ahead.
14. AVOIDING CONTACT
A boat shall avoid contact with another boat if reasonably possible. However, a right-of-way boat or one sailing within the room or mark-room to which she is entitled need not act to avoid contact until it is clear that the other boat is not keeping clear or giving room or mark-room.
17. ON THE SAME TACK; PROPER COURSE
If a boat clear astern becomes overlapped within two of her hull lengths to leeward of a boat on the same tack, she shall not sail above her proper course while they remain on the same tack and overlapped within that distance, unless in doing so she promptly sails astern of the other boat. This rule does not apply if the overlap begins while the windward boat is required by rule 13 to keep clear.
18. MARK-ROOM
18.1. When Rule 18 Applies
Rule 18 applies between boats when they are required to leave a mark on the same side and at least one of them is in the zone. However, it does not apply
18.2. Giving Mark-Room
19.1. When Rule 19 Applies
Rule 19 applies between boats at an obstruction except
19.2. Giving Room at an Obstruction
18. MARK-ROOM
- between boats on opposite tacks on a beat to windward,
- between boats on opposite tacks when the proper course at the mark for one but not both of them is to tack.
- between a boat approaching a mark and one leaving it, or
- if the mark is a continuing obstruction, in which case rule 19 applies.
- When boats are overlapped the outside boat shall give the inside boat mark-room, unless rule 18.2(b) applies.
- If boats are overlapped when the first of them reaches the zone, the outside boat at that moment shall thereafter give the inside boat mark-room. If a boat is clear ahead when she reaches the zone, the boat clear astern at that moment shall thereafter give her mark-room.
- When a boat is required to give mark-room by rule 18.2(b),
- she shall continue to do so even if later an overlap is broken or a new overlap begins;
- if she becomes overlapped inside the boat entitled to mark-room, she shall also give that boat room to sail her proper course while they remain overlapped.
- Rules 18.2(b) and (c) cease to apply if the boat entitled to mark-room passes head to wind or leaves the zone.
- If there is a reasonable doubt that a boat obtained or broke an overlap at the time, it shall be presumed that she did not.
- If a boat obtained an inside overlap from clear astern or by tacking to windward of the other boat and, from the time the overlap begins, the outside boat has been unable to give mark-room, she is not required to give it.
- when the obstruction is a mark the boats are required to leave on the same side, or
- when rule 18 applies between boats and the obstruction is another boat overlapped with each of them.
- A right-of-way boat may choose to pass an obstruction on either side.
- When boats are overlapped, the outside boat shall give the inside boat room between her and the obstruction, unless she has been unable to do so from the time the overlap began.
- While boats are passing a continuing obstruction, if a boat that was clear astern and required to keep clear becomes overlapped between the other boat and the obstruction and, at the moment the overlap begins, there is not roomfor her to pass between them,
- she is not entitled to room under rule 19.2(b), and
- while the boats remain overlapped, she shall keep clear and rules 10 and 11 do not apply.
