Folding prop
Oct 9, 2022
61
Catalina 30 Stratford CT
I inherited a Catalina 30 and with it this scrap yard prop. Before I bang on it, what is the correct way to remove the cut-off prop shaft? That square recession has my attention.
Thank you!
Carl
If your going to take the prop in to be serviced, why not take it as is and let the shop do all the work.
Looks like an Eliptec Folding Prop
You might want to seek out replacement parts, before you get to deep in the woods on the project. It looks like someone took a hammer to the prop at one point. I would guess an attempt to get it off the shaft.
Likes: Cederholm
I was planing to service it myself, but it’s a thought.
It would be difficult to service the prop yourself. Part of the service is to fill and re-drill the holes for the pivot bolts and to add more bronze to the worn areas. Mechanically these are really simple props, however, over time the opening of the props causes wear on the hub and on each blade where it mates to the hub. The wear affects the blade angle, so they will open more than 90° and resist opening in reverse.
Like @PaulK we had on on a prior boat and it worked well and was low maintenance. I had the boat for 13 years and sent the prop in to be serviced once when the boat was about 25 years old. It was probably the first time it was ever serviced.
Likes: Cederholm
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
The "correct way" is to use a prop puller and a 3-inch long 1/2" socket extension. On the workbench you might be able to get away with a 3-armed gear puller.
Likes: Cederholm
Jul 1, 2010
990
Catalina 350 Port Huron
I'd have someone set it up on a hydraulic press (carefully) with the 1/2" extension like mentioned above.
Likes: Cederholm
