The only way to remove VC 17 is with a sander and aggressive sandpaper. Been there, done that.
www.practical-sailor.com
My go to is now those disposable suits with the hood.Still had red dust in my ears, hair, clothes…and my RO sander has never been the same since
That is my plan in the future. Lots of the original brand and cheaper clones out there. Would pay for itself after a couple uses if it saves buying a new vac.I use an Oneida Air Systems Dust Deputy (Amazon link) with a larger shop vac equipped with a filter bag and HEPA filter. This is virtually dust free.
Yes... Methlyene Chloride is bad stuff. Unless you have studied the MSD sheet and know what you are doing, I recommend avoiding any hydrocarbon material that contains a chlorine atom.Was just searching practical sailor's website for unrelated stuff and found this page about strippers.
Boatyard Chemical Wisdom - Practical Sailor
We identify the boatyard chemicals that are hazardous, banned, or best replaced—and what to use instead.www.practical-sailor.com
Interesting info about NMP and Methlyene Chloride
@rgranger DIY mix sounds better and better.
It is not without some hazards. DO NOT get this stuff in your eyes. And any skin that gets exposed will become very dry, crack and take a week or so to get right again. The strong base actually turns the oils in you skin into soap and they wash out leaving raw hide where you soft skin used to be.@rgranger DIY mix sounds better and better.
Thanks!!I used to post on here a receipe for homemade peel away. YOu take a 5lb bag of garden lime, two cups of lye and put it in a 5 gallon PVC bucket. Add just enough water to get a melted peaunut butter consistancy and then roll that on the bottom paint... the garden lime is there just to add a paste that helps hold the potassium hydroxide (lye) to the paint. If it is hot and dry where you live, you may need to cover it with plastic sheeting so it does not dry out before it is done working... some receipes also add glycerin to keep it moist.... a 10lb bag of sugar will also do the same trick but if you have ants or bees around that might not be a good idea. The ingredients are so cheap I'd skip adding sugars and/or coating with plastic sheets and just do it more than once if some of the paint does not come off the first time. Less mess and hassel that way.
Easy off is also just a very strong base, suspended in some binders to help hold it on the surface you are using. But to do an entire boat it will cost you a lot more. A can of easy off is $5 and you will probably need 20 of them. The entire 5 gallon PVC bucket approach is only $15. If you are going to do the entire boat, the PVC bucket way is much less expensive. I've done this a dozen times.... almost all of the paint will sluff off in big sheets... and for some reason there is always one or two spots that won't come off ... so I put a little citrus strip on those spots. Nice smooth bottom without sanding off any gel coat.
Hehe. I would traditionally figure that would be obvious, but with younger generations I am not so sure.It is not without some hazards. DO NOT get this stuff in your eyes. And any skin that gets exposed will become very dry, crack and take a week or so to get right again.
How were they blasting it?Was going to have it blasted, but was quoted $6,000???? Seems crazy for a 43 foot boat.
It really works well... does not touch the gel coat. I have fully restored seven sailboats... and have helped a half dozen friends work on theirs... The first time I tried this receipe was on my third boat.... so... that means I have sanded at least three sailboats and know what a PITA it is.... when I did this the first time and hit it with the pressure washer... I just started laughing. The paint just sluffed off in big sheets. It was a very pleasant surprise.Thanks!!
After you do this do you wash the bottom with anything or just rinse? I have been having issues with paint adhering since yard has been doing the work. Think the initial time they painted it was cold and raining and the paint never got hold. Have been sanding and still having issues. Have to try a more thorough removal. And does it just remove the ablative paint and leave the barrier coat fine? Was going to have it blasted, but was quoted $6,000???? Seems crazy for a 43 foot boat.
You could start a business - sandingsucks.com
saillifeshop.com
