A
Anon 156829
Hello,
My Catalina 310 has an ongoing issue related to voltage readings.
My voltage meter pins itself (15-16) from time to time. Usually when a load is introduced.
After replacing battery 1, things seemed to settle down. Then I activated my auto pilot the other day and that sent my volt meter into hyper mode.
I have 2 Interstate SRM 4D batteries. Just replaced Battery 1 as the issue seemed to be isolated to it. Now the issue has reared itself with both batteries. Replaced the alternator as well (regulator is built in to alternator). The issue is intermittent. Sometimes it works fine and sometimes not.
Wondering if the Volt meter is the next swap out.
* Yes the batteries have been load tested resulting in replacement of Battery 1. All connections have been inspected and secured. Don't think its the regulator as it is built in to Alternator and that is brand new.
Any thoughts are appreciated.
