engine: belt too much slack and water drop
Mar 6, 2008
1,505
I just don’t have that tool
thanks so much!!!!!
The video was perfect.
One confusing part is the need of the modified allen key. I don’t see at which it would be used in the video. Do I need one?
Thanks for pointing that out. That text was posted by a visitor Bill Dollan, it was a comment by someone else.
That's because I did not post the video.
In the link I provided are embedded links to at least three more informative articles about this very subject, one of which explains the why, and my link discusses it in detail. Remember the part that says: "I bought the Allen wrench, and with the help of a neighbor's grinder, cut it down and got to work." I guess not.
xavpil
Sep 6, 2022
376
Jeanneau Sun Odyssey 419 Milwaukee
my bad for PM. I’m new on the forum. I clicked the wrong reply button I guess. A simple “please don’t PM me would have been enough. No need for calling me a dude. No one forces you to reply or help. If I’m dumb then move on another Thread. I’m new with a sailboat. English is my second language and technical language is my… fourth.
Likes: jon hansen
Found the allen key file. This key goes down thru the seal to the underside and helps remove the sealView attachment 210157
@RitSim is right.
This is the text of my earlier link and it includes an embedded link to that simple Allen key:
Thanks to you, Ron Hill and his May 2002 rebuild article, the Sailnet discussion, and a fine Sunday afternoon.
In 1999, when our new-to-us boat's raw water pump started leaking, I went to the local Universal dealer, who said: "It'll cost more to rebuild your pump than to buy a new one."
Being A NEWBIE, I did. Actually, it was a pretty neat deal: $176 + tax in 1999 $$s, and all it took was four nuts on the studs to remove the pump and replace it.
Recently, I've seen evidence of leaks (see the Critical Upgrades sticky topic for "checking your engine").
Time for a costly new pump?
Wait!!! I'd read about rebuilding a pump. I read Ron's Tech Notes article, and then literally stumbled across the linked Sailnet discussion.
It was SCARY at first, whacking the pump's innards, but once I realized that the pump is like a tank and the seals are simple replacement parts that can get knocked out, removed and replaced, it became much easier.
Using a pair of needle nosed vice grips makes holding the wrench pretty easy, if not necessary.
The idea from Sailnet about the 12P nail worked, too, 'cuz the Ron Hill tool may be too thick to get between the carbon bushing and the water seal.
Sweet feeling when the old ones came out.
Easy to get the new ones back in with a piece of wood and a socket.
Another helpful link that links back here: rebuilding Oberdorfer Pump
This link is important because it shows the tool that Ron Hill built to get the old seals out (1/4 inch hex head Allen wrench ground down to fit). second picture, link to Ron's article: http://www.c34.org/mainsheet/pdf/May_2002.pdf
The C34 Tech wiki also has that article: Raw water pump, impellers and cooling system - c34.org
