Got a call into Butch at the yard. Waiting for a reply. Hopefully Butch will be able to tell me any tricks. I know the bolts had never been removed so I assume he had some sort of trick since so many came out without damage.
By the way. If push comes to shove, I believe the store here has the chocks with the rollers for sale as a complete unit. With the carriage bolt arrangement (which I can confirm they are) you can't just cut off the round head and drive it downward. There will still be the square portion in the "square" hole of the toe rail so it won't go through the round hole in the hull to deck joint. You almost have to take it out driving it from the bottom but maybe with the head off you can get something into the corroded joint to break the bond.
I'll let you know what Butch says when he calls me back.
Smokey
Smokey
