Question about water heater setup on Hunter 36
AndyL
Jun 23, 2020
151
Hunter 36 Rock Hall
I have a 2004 Hunter 36 with a Force10 6-gal water heater that needs replacing. I'm replacing it with the identical model that is now made by Kuuma.
I can't find anything in the boat manual to say whether or not we have an expansion tank in the system... does anyone know whether or not we do and, if we do, where it is?
Thanks,
Andy
Jan 4, 2006
7,281
Only on a custom built boat. Test to see if an accumulator is installed by a previous owner.
1,746
I doubt it- not installed by Hunter but could have been added by dealer/owner. doesn't affect water heater hookup. if there is one, look for a small tank somewhere under the sole near the water pump
Likes: ggrizzard
AndyL
Jun 23, 2020
151
Hunter 36 Rock Hall
OK - thanks.
Here's why I'm asking... my old tank has the Kuuma valve that regulates engine coolant flow into the heater when the engine is running, to stop hot water temps getting too high.
That valve is no longer made and there doesn't appear to be any substitute.
Has anyone who used to have the old valve shown above removed it when installing a new water heater? Did you have any issues or do anything special to accommodate the higher water temps and water expansion in the water heater?
Thanks.
Jan 4, 2006
7,281
My setup doesn't have any controls on the DHW and it's never presented a problem. Just make people aware that it COULD get very hot.
The accumulator tank is a necessity to keep the relief valve from weeping as the temperature comes up. If your water pump is a straight OFF/ON control, test to see if the pump keeps pumping after an outlet is closed. If the pump stops immediately, no accumulator OR the accumulator has failed. Your choice.
Likes: ggrizzard
AndyL
Jun 23, 2020
151
Hunter 36 Rock Hall
The water pump stops immediately after an outlet is closed. I haven't noticed any obvious leakage from the water heater when it is turned on. I'll look around when I get down to the boat later in the week.
expansion tank
It is not called an "expansion tank"... it is known as an "Accumulator"
Two examples of what they look like.
This is a Shurflo
This is a Jabsco
Accumulator Tank - 20 PSI
Description
Pre-pressurized with built-in diaphragm, the Shurflo Accumulator Tank smooths water faucet pulses and reduces pump cycling to keep line pressure up and pump motors cool. Unlike other similar tanks, the Shurflo Accumulator incorporates a butyl rubber diaphragm to maintain pressure for years, rather than days with traditional tanks. Reduces cycling pulsation and pressure spikes, increases the life of your pump and even saves battery power.
• Ports: 1/2-14 NPSM male straight thread; will seal with 1/2" female NPT; second port may be capped, as applicable
• Pre-charged to 20 PSI
• Dimensions: 8.90"H x 4.06"D
Here is a third design. This is also a Jabsco
Mar 20, 2004
1,746
Are you sure that 's regulating coolant flow? That sounds odd - because if you restrict the coolant flow there - it's one loop thru the engine- you restrict flow thru the engine. Since that valve is installed on the "hot out" connection, I'm betting it's a non-adjustable tempering valve that blends cold water (the red tube??) with the hot water to moderate the temperature on the faucets. I didn't have anything like that, so I added a tempering valve to protect the grandkids. about $35 for the valve on amazon and it works great; I could adjust the hot water down from 180 degrees to 120
Likes: Allan12210
Jan 4, 2006
7,281
Which the fix to the latter may be a simple as recharging the accumulator with a bicycle tire pump.
You would have to introduce facts and complicate things :angry: !
Even with all of the compressed air removed from the accumulator, I'd expect the diaphragm to accept some water giving the pump a second or two to build up pressure. I've seen this in mine when the interior pressure near zero.
Definitely not proof positive but it "likely" means there isn't one in the piping and the OP wasn't able to find one to boot. Having two chambers will do even a better job if there is in fact a first one.
Jan 4, 2006
7,281
One loop is through the engine and a parallel loop is through the HEX so no problem.
That was my guess as well. Mighty fine SS casing on the heater tank.
RoyS
Jun 3, 2012
1,742
You need a mixing valve at the hot water outlet to regulate output temperature and prevent scalding. I use a Honeywell AM-1 equipped with unions and threaded fittings on all three ports. There are also models of the AM-1 with pex or sweat fittings, so be careful with your selection. Reasonably priced, adjustable temperature setting, and reliable.
Likes: tfox2069
Hunter 34 Alameda CA
OK - thanks.
Thanks.
Can you just swap that from the old heater to the new one?
If it is indeed a thermal regulating valve, here's how I added one to mine. Rather than trying to regulate the engine coolant into the water heater, I chose to regulate the output into the rest of the fresh water system. Plus the added bonus was that it seemed like we had more heated water available when away from shore power. Not as much was purged from the water heater while we were trying to dial in the appropriate temperature.
AndyL
Jun 23, 2020
151
Hunter 36 Rock Hall
Thanks for all the feedback. Some answers:
- I did buy the Jabsco plastic accumulator tank shown above. Now I have to find a location to install and get the correct connectors. We have the 15mm red and blue plastic piping and it's not so easy to find fittings. It is also less flexible than normal hose, so that doesn't help because some locations would require too much bending so that either means a different location or adding more right-angled connectors (and I always prefer to use the minimum number of connectors).
- I will try to reuse the existing valve from the water heater but I want to be prepared with options if that fails.
- The valves that mix cold into the outgoing hot seem to be the only solution now so that may be the way I go unless I can reuse the old valve.
- The more changes I have to make, the more the hot and cold water pipe routing changes and, as mentioned, these plastic pipes are less forgiving of significant changes in location or direction.
- I am still working out how to get the engine coolant to drain without making a mess when I remove those pipes, plus how to avoid air when I reconnect them. I'm sure it's not rocket science :)
Regards,
Andy
