brand new 1 GM 10. Mechanic said 'it ran fine after install in late April. ' Boat sat in the marina , launching was delayed til 8/25 (due to family health problems. ) Engine wouldn't start, so I called the mechanic who installed it. He said to put gearshift in neutral gear, put full throttle on and try to start it. I tried 3x, 10-15 seconds per start, no joy. checked again : fuel tank full, fuel shutoff in open position, no junk or water in new RACOR bowl , batteries good.
Tomorrow I'm going to try to bleed at the top 10 mm bleed bolt of the secondary filter (assuming the miserable little manual - lever pump isn't in the wrong position relative to the cam to pump fuel. )
Questions :
1/ If the manual pump doesn't work, how do I turn over the cam to get the pump in proper position to pump fuel?
2/ how do I know if it's necessary to crack at the injector, and if I need to do this what' involved in pulling up the (one) decompression lever on my one little injector ? (that process isn't covered in the slim 'owners manual' that came with the boat. . )
Yanmar's new instructions on this particular 1 GM say to pull engine stop cable full OUT (to stop position, meaning no fuel ) then push the stop lever gradually back towards full open while pressing the start button, thus giving it fuel ' til it catches. ' The maneuvering of the main throttle lever to full speed while in neutral gear , then backing the main throttle off to idle as suggested by the mechanic appears to do the same thing. Do you wise engine people see any pros or cons to either of these methods?
thanks (and fairer winds than we have on lake erie now)
I'm about to bleed at the secondary filter and see if fuel comes out. if it does, do you experts recommend my trying to turn it over over w raw water seacock inlet closed , then open the seacock ASAP if it catches ? I sure don't want a hydro lock.
Questions :
