Hello all, when sailing/anchoring with family, I find it anxiety-inducing to monitor the holding tank through guesswork. Early in the filling process it's low risk to hold my breath, unscrew the black port cover, and check the level. Later in the process, this is a *very* risky procedure. Why didn't they make a transparent cover or strip up the side so quick visual inspection is all that is required? Has anyone found a solution for this problem?
