I cannot even begin to express my gratitude towards you. Our fridge (Grunnert 450) failed just like yours. We brought out our HVAC guy and he could not find the issue. I clearly remember him testing the capacitor and relay, and then we discussed. We were in talks with Sea Frost to replace evrything, (still waiting on a quote) and my son found this post. I didn't even bother doing the tests you described. I found a brand new relay $13 and change and contacted BMI (Paul Shockly is no longer there). They got right back with me with news of stock on hand. I ordered the capacitor ($54 with shipping), installed the 2 components and we have a working fridge!!!! Thank you thank you thank youHello All,
Hope someone has experienced this problem and may have some helpful debug guidance.
Problem Description:
When I turn on my refrigerator AC breaker on my A-bus power panel the sea water pump does not turn on, my generator voltage drops to about 30 AC Volts. The breaker on the power panel then may trip, may not. Some times the system will come up, other times the compressor will barely operate, the sea water pump doesn't turn on, I get high current demands and the breaker trips.
Debugging done so far:
Assumption: sense the pump sometimes will turn on and the refrigerator will run without issues due to intermittent problem, I'm assuming the pump and the compressor unit are good.
1. Pulled the Grunert electrical box cover off and checked the run capacitor with a multi meter. The capacitor charged from 0 ohms to infinite ohms indicating it is a good capacitor. AMRad P/N 33291 15 uF 370VAC 50-60Hz Motor Run capacitor
2. Checked the Motor Start capacitor BMI 092A270B330DE8X 270-324 uF 330VAC. The DE8X capacitor has a resistor tie between the pin connections thus should increase the RC time constant for a tuned charge time. I don' know if it should be long or short. The multi-meter check showed that the capacitor charged by very slowly. It was in the low ohms for several seconds. This to me suggests possibly the capacitor may be bad. I could never get it to go to infinity (fully charged).
3. When I measure the start capacitor in-circuit I measure 0 ohms across the leads. I don't have a schematic of the Start Relay so I don't know if the start capacitor is normally made when de-energized.
Any Idea's are welcome.
