Hi all,
Earlier this summer, I noticed some faint gel coat cracks at various points across the swim platform of our 2006 Hunter 25. I thought it might be surface / cosmetic due to age and flexing, but I have seen more cracks appear, and some progression of existing cracks over the past few weeks. I know the right thing to do is to have the above repaired properly, but that would put an end to this summer’s sailing season unless I find a shop that can fix this ASAP (am not having much luck with this option so far).
Here’s a summary of what I have observed for stress cracks. See attached photos for items 1 and 2, below.
Stress Crack Locations:
Thanks for any information anyone can provide.
Rob
- Inboard forward motor mount hole. This location is where the cracks have progressed the most. There are four bolts for the motor mount. If one is standing on the swim platform, looking forward and down from above the mount, the one with the cracks would be the upper left of the 2 x 2 bolt pattern.
- Rudder mount. These are faint long cracks that run from the aft edge of the swim platform forward and around the entire raised rudder mount “hump”, and one crack that runs more or less vertically down on the port side (rudder perspective) of the rear vertical part of the swim platform.
- Forward edge of recessed area of the telescoping swim platform ladder. These don’t appear to be structural, and may be related to someone banging the ladder down without it being fully retracted.
- If I attempt to move the Tohatsu 9.8 fore and aft, I can see a small amount of flexing near the stress crack. This makes sense, of course.
- There are places on the swim platform where I can feel some slight flexing and crackling noises when I stand on them. Not a good noise, for sure.
- I haven’t had time to crawl into the aft compartment to take a look from underneath the swim platform, but I’m going to do this sometime in the next several days.
- Is the swim platform reinforced other than the embedded aluminum bars for the motor mount bolts? Am wondering if there is marine plywood in between the fiberglass layers. I may be able to determine this when I look underneath it, but I haven’t been able to find this information online.
- The big question that is difficult to answer without seeing the above in person: Is what I’m describing dangerous enough for us to stop using our boat until this issue is addressed? If the swim platform is completely reinforced with plywood or other core material from side to side, I would be a bit less worried about a catastrophic failure of the motor mount. My immediate action would be to focus on preventing water intrusion through the cracks for a few more weeks until we can get her to a repair shop.
Rob
