420 outhaul length
Apr 12, 2007
210
Hunter 420 Herrington Harbor South
I am trying to replace my outhaul on my Hunter 2005 420 but cannot find the specifications for type and length. Owner's manual does not have it nor can I find it in the Selden website/manuals.
Anyone have a good reference?
Furling Mast or Loose Foot Main?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Odd your owners manual, as well as mine, did not list the outhaul specications. I replaced my 2005 furling mainsail outhaul with 70 feet of 3/8” diameter Samson XLS Extra. To confirm the exact length for your 420, attach a tag line to the end and pull it through, remove the old line, measure, purchase new line and install by reversing the process with the tag line.
Apr 12, 2007
210
Yes, furling mast system.
That was the backup plan if no one knew the length. thanks
Uhm, the outhaul on my 356 was continuous (Perhaps that's why no length is specified). Nevertheless, I replaced it with a high tech ultra low stretch line. It made a world of difference in the sailing characteristic of the boat. Specifically when a gust of wind would hit, the line would stretch very little and instead of the sail becoming deep, powerful and drag laden, it would remain flat. The boat would lean over and then come back up with acceleration as it's supposed to do. I would advise that you get the best line you can get for this important sail control.
Sep 22, 2021
294
Hunter 41AC 0 Portland, OR
You can calculate the total length of the existing line by measuring the various sections and adding them up. For example, measure from the eye at the end of the line to the clew of the sail, and from the clew back down to the outhaul car, and from the car out to the end of the boom, and from the end of the boom to the mast, etc. all the way back to the cockpit. If you're nervous about your calculation, add a few feet as a safety margin.
I used this technique on all of the running rigging that I recently replaced and it worked out fine.
Apr 12, 2007
210
That is what I finally did. replaced with no issues. BTW 70ft is the correct length.
Thanks all
110
Hunter Passage 420 Rock Hall, MD
What size line did you finally use and type. I need to replace mine.
