Am I correct that water from the galley and head sinks drain directly to the ocean via a throughfitting under the waterline? What about the shower? I have a sump pump panel switch, a sump pump switch under the lip of the head sink (no idea which position is on or off) and a jabsco 50psi model 31395-3000 under the deck between the head and the nav table. I cleaned the filter (the glass plate with red ring in the pic); the disgusting impassable stinking matted hair and decaying (what!?) lead me to believe it is the sump pump. When I turn on the sump pump panel switch, a light goes on, but no reaction from the pump, regardless of the position of the switch on the head sink. Is it possible that the pump burned out because the prior owners did not clean the filter, letting the pump run dry til it died? If this theory is not an entirely ignorant idea, how might I test if the pump is burned out? Where is the seacock on the sink drain...? I apologize if some of these questions seem silly ... am learning ... fast. THANK YOU All of you!
