Hi all,
I own a '73 C&C 30 MK1 with a weight of 9700 Lbs loaded. I would like to put a set of chainplates on the port and starboard aft sides to attach a Farentino shark drogue. I'm not sure of an adequate size and was wondering if I could get some advice. I have been reading on the forums for info, I have read it is a good idea to have;
1. One inch of material between the shackle hole and the end of the chainlate,
2. Chainplates made from 316 Stainless Steel,
3. 1/4 inch thickness of chainplate,
4. Mounting holes of chainplate to vessel are staggered.
I thick these suggestions are good ideas, my questions are;
1. How long and wide should the chainplate be to accommodate 9700 Lb vessel,
2. Number and thickness of mounting hardware from chainplate to vessel, i.e. would 3/8" be adequate or go with 1/2".
3. Would it be advantages to have a slight bend in the end of the chainplate to line up the shackle to the bridle, if so, what degree of bend.
Any help would be greatly appreciated, one thing I wish to avoid is ripping the chainplates from the hull due to forces placed on the drogue.
Cheers,
Tom
Cheers,
Tom
