While it seems that there is no blockage and water manually flushed from the head flows through to the holding tank, water escapes from the unit handpump while pumping and after several minutes gray water seems to leak back into the bowl, even after completely emptying the bowl and locking the pump. It seems the prior owner purchased an entire head unit and replaced only the upper half of the unit (ie, the old base of the unit remains screwed to the floor). Of course, over time this begins to smell. The leakiness of the seals seems to have worsened over the two months since purchase of the boat, despite almost no use.
