For your AC circuit you need too look at the total AMPS you plan to use and plan your wiring accordingly.
Look not only at the running AMPS but the start load. A refrigerator starting and stopping will put a heavier load on the circuit than the when it is running or resting.
Loading up a single circuit with a series of heavy AMP use loads will mean the breaker will be opening a lot when all of the appliances are in use at the same time.
"Hey honey I am going to use the hair dryer... That's ok, I'll pop the coffee in the microwave... just then the temp in the refrig is rising and the machine's brain says START THE COMPRESSOR!... Pop... goes the breaker.
DAMN! there it goes again.... Maybe I need a bigger breaker...."
![Eek :yikes: :yikes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
NOooooo!
