Oil Change 18hp Yanmar
LynnM
Mar 7, 2021
15
Beneteau 323 St Clair Shores
I have a Beneteau 323 and want to change oil.
I'd like to suck it from the dipstick hole which is VERY small, less than 1/4 inch tube. Any ideas on what size works and where I could find one? What I ordered from Amazon only goes in about an inch, not near the base of the crankcase.
May 27, 2004
2,059
I have a 2GM20F Yanmar with the same issue.
I bought a clear, polymer tube at the hardware store that reaches the bottom of the oil pan.
It fits the outside diameter of the black plastic tube that came with my oil extraction pump.
I can't recall the diameter of the extension tube, but you could get a small length of a couple
of diameters to determine which fits.
Remember to warm the engine oil before extraction.
LynnM
Mar 7, 2021
15
I have the identical engine.
Thanks, I'll try several other places.
The smallest tube I could find will not fid to the bottom of the pan.
Jan 7, 2011
5,864
Oday 322 East Chicago, IN
I also have a 2GM20F engine. I purchased one of the on Amazon and it includes several different size tubes. I use the largest one that fits into the dipstick tube.
Dec 25, 2000
5,951
Hi Lynn, I've used one of these for years, both on our first boat with a 2GM, and our current boat with a 4JH. Works great and has the plastic hose that fits into the dip stick pipe. https://www.amazon.com/America-5060...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I have one of those, too, Greg. Work great. My plan, though, is to install an electric oil change pump with a manifold and selector valves so I can pump out and pump in oil for both the engine and transmission. A guy can dream, can't he? :)
RoyS
Jun 3, 2012
1,742
On my Yanmar 2QM15 I can insert the pump pickup tube down through the oil fill port on the valve cover, wiggle it over to the rear corner of the push rod opening in the block casting at wiggle it down to the very bottom of the oil sump. I can pump out just about the entire specified capacity for oil in this engine. Conversely, using the dipstick port leaves about half the old oil in the sump. Takes a little patience but works for me. If you use the dipstick port, it would be best to run the engine after you fill it with new oil and then change it again to improve your results. I have done both and prefer using the oil fill port for a one shot oil change. Works on a two cylinder but maybe not on a larger engine.
Jul 7, 2004
8,501
Hunter 30T Cheney, KS
The secret is to warm up the oil before you try to suck it out. It will never work otherwise.
I bought a manual pump mentioned in Practical Sailor. It has a straw-like tube that works well
senang
Oct 21, 2009
316
hunter 38 Monaco
When I look at the suction tube of my vacuum pump it looks suspiciously like the outside of a bike’s brake cable. If I were you go to a bike shop and buy a brake cable, remove the inside and check if it fits. I don’t think this will rake the bank.
Jan 7, 2011
5,864
If you just need a smaller diameter hose, I would think Ace Hardware or similar home improvement store would have a large selection of tubing. Has to be cheaper than buying bike cables…
Oct 6, 2007
1,164
Hunter H30 1982 Chicago IL
I use this oil extractor for my 13 hp Yanmar 2GM engine. The engine needs to be warm for it to work. Jiggle the tube around a bit. I found that if I jam it in too hard, the tube seems to bend upward inside the oil pan and sucks air instead of oil.
