Groco or Apolo thru hull Vaves?
Jun 4, 2004
292
Hunter 49 123
my ac valve failed in the close position. have choice of Groco or Apolo. any difference in quality?
Feb 10, 2004
4,256
Hunter 40.5 Warwick, RI
Just check that the valve is bronze and has no brass. I am not sure but I think some Apollo valves intended for household use may have brass. You need to check.
JamesG161
Feb 14, 2014
8,111
Hunter 430 Waveland, MS
No brass in the Apollo marine Bronze valves.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
The ball in the Groco valve is chrome plated brass. So it appears that at a lower price the Apollo is superior, at least in this aspect.
Dec 1, 2020
39
Hunter 44 DS Deale, MD
Velero, please make sure you understand the possible thread mismatch between thru-hulls and the screw on valves, no matter which brand you go with. MaineSail has several excellent articles on his website about this.
Many Hunters, including mine, came with mismatched threads from the factory.
Jun 25, 2004
674
Hunter 306 Pasadena MD
I have Apollo seacocks on our boat (installed by Hunter), as well as 3 Groco seacocks I replaced the Apollos with in 2020. I'd absolutely go with the Groco. I used the 1-piece with the triangular base (which some criticized b/c you'd have to replace the whole thing if the seacock fails), but I'd use the same if I did it over again.
BTW: there's a certain pucker factor you have to get over when you're installing a new thru-hull for the first time, but it was really no big deal. Well... figuring out how to do the backing plate was a small deal. I went with the Groco backing plates, but probably would do a fiberglass disk if I had it to do over again. Not for any reason I can defend: the Groco backing plates worked just fine.
