When using a whisker pole on the foresail, the proscribed method appears to be attaching one end of the pole to the sheet that will be used to trim the sail and the other end (of course) to the attachment on the mast.
On our recent race, the crew and I were having trouble keeping the whisker pole close enough to the jib clew to be effective, and our foredeck crew member just resorted to camping out on the foredeck to push the pole back into place. Bit of a hassle.
I have read that keeping the sheet end of the pole in place is accomplished by keeping proper tension on the jib sheet, but it seems to me that running dead downwind that once you get that tension set, things should stay pretty much as set. I would rather have the crew in the cockpit, especially running downwind.
My Genoa has a metal ring at the clew to which the whisker pole would easily attach. Doing so would solve the problem of it slipping back away from the clew, but is there any reason that this would be a bad idea?
Thanks in advance for you thoughts/advice.
