I'm trying to figure out what the size the factory furling headsail is on my 2007 Hunter 38.
It's not in the manual (that I can find).
..... the shortcut is to simply compare the LP with the J.@flightlead404 , Joe has answered your question. You're going to have to measure to get the answer.If the J is 10 and the LP is 11 then the size is 110.
Measure the sail, too. Since you know the IJPE measurements, then compare the sail measurements, like this:I meant, its it 110%, 115% or something else.
I cannot find THIS information in the manual
Measurements for this purpose and for the purpose of ordering new sails are sail only, right? That is EXCLUDING the 1.5" loops at the head and tack used to attach to the furler?Measure the sail, too. Since you know the IJPE measurements, then compare the sail measurements, like this:
It is the ONLY way to answer your question.
YesThat is EXCLUDING the 1.5" loops at the head and tack used to attach to the furler?
Excellent thanksI replaced my factory headsail last season with a sail of the same dimensions. The sailmaker labeled LP as 110%.
Furling mainsails do not trim out as well as a loose or shelf foot main. However, a well cut furling main can get your pretty close to a non racing level of sail trim that most of us would find acceptable. There is a cost for the convenience of mainsail furling... but the level of trim control has been rising as sail and equipment designers innovate and create. Inflatable battens for instance.Also, I think some of my main sail furling issues are to to that problem.
I just did this. Measured LP on existing sail and re-measured J. My LP/J shows about 119%, so call it 120%The very easiest way to determine sail size is to compare the headsail's Luff Perpendicular (LP) with the boat's (J)
LP is a perpendicular line from the sail'l luff through the clew of the sail. In geometric terms this line represents the height of a triangle and the sail's luff represents the its base
The J is the distance from the stemhead to the mast base... it is the foredeck length. It also represents one side of the right triangle created by the mast, deck and forestay.
Anyway, a comparison of the areas of these two triangles will give you a percentage number that represents the sail's size.
Sail area 110sq ft divided by foretriangle area of 100 sf = 110%
But WAIT.... did you forget your jr high school geometry?..... the shortcut is to simply compare the LP with the J.
The J is often stated with other common dimensions in the sales brochure or sailboatdata.com information sheet.
Nerd alert. The amount of overlap depends on the shape of the sail. (high clew, low clew etc) So it is inevitable that a 100 % headsail will, in fact, have a clew that will overlap the mast.
Nerd alert 2..... the LP is NOT the same as a sail's FOOT.... don't blow it with the old salts by confusing the two.![]()
