Clamcleat replacement for jib sheets
Sep 13, 2021
159
Catalina Capri 26 280 Lake Jacomo
I know lots of people recommend Spinlocks for the jib sheets, but I saw a post here about using these clamcleats because the screw holes are an exact match. I like the simplicity of that. Does anyone have any experience using this type of replacement?
No, but aren't jib sheets usually handled with winches? Seems those clam cleats might be a possible hang up.
:plus: I don’t know how jib sheets are usually secured on boats of this size, but anything with a fairlead like that would concern me.
Sep 13, 2021
159
Hmm, well I'm a beginner, but I haven't used the winches for the jib yet. The boat came with clamcleats similar to these but the design was poor. They're a pain to use. Here is the thread where I saw this. There is a pic of the original in the post.
Sep 13, 2021
159
I'm a beginner, but can I ask why a fairlead would be a problem? I thought that would be a benefit so the sheet would not lose position when released during tacking.
MrEd
Jun 5, 2004
72
Hunter 240 Louisville, KY/ Patoka Lake,IN
You’re right when it comes to larger boats-a different world. However, the 240 has a small <100 % jib and in most situations the winch isn’t necessary.
Jun 29, 2010
1,287
Every boat I have been on and the vast majority I have seen that do not have self tailers use a cam cleat. Standard Cam-Matic® Cleat - 150
Yep, new holes but the old ones are easily filled. Get some butyl and some West System and have at it.
-na -NA Anywhere USA
First there is an aluminum plate embedded in the fiberglass where the hardware is attached. Look for the raised area. Secondly the jib is a 110 max only. You could attach either a fixed cam cleat with strap or a swivel cam cleat. You do not need a winch to raise the jib with.
