This is a question about proper grounding of the start and house batteries. Is this the proper connections for grounds or should both batteries go to a common neg buss bar?
Current setup. My house battery neg is connected to B- on the alternator. My start neg is connected to a starter bolt. The only connection between the neg terminal on the two batteries is the engine block.
Here is a diagram of my battery connections.
Note that the battery switches only control battery discharge and that charging is independently controlled by an ARGO FET so that both batteries are connected to the alt anytime there is charge current.
The start AGM output goes to a 12BO switch terminal 1
The house LFP output goes to a 12BO switch terminal 1
There is an emergency jumper lead connected to terminal 2 on both switches.
